Old 09-22-2018, 04:33 PM   #1
gpvecchi
gpvecchi's Avatar
TapTurn issue
Guys, I fitted the TapTurn relay to may brand new 86, but I have a lot of issues: I can't program the leaving/approaching timer, nor the strobo. And parking light doesn't work. My car has keyless entry.
Can you please help me?
gpvecchi is offline   Reply With Quote
Old 09-22-2018, 09:29 PM   #2
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
You're following the instructions right? Why not contact tap-turn themselves....
Old 09-23-2018, 04:36 AM   #3
gpvecchi
gpvecchi's Avatar
I tried but it’s weekend. I followed instructions, I was looking for some feedback here...
Old 09-23-2018, 01:56 PM   #4
FRSBRZGT86FAN
I have no issues with mine, I simply followed the instructions and it worked. Definitely suggest contacting them:
http://www.autowindow.com/install-instructions
websales@autowindow.com
Old 09-23-2018, 03:08 PM   #5
gpvecchi
gpvecchi's Avatar
Contacted, they say thay 2018 with keyless can have different wiring, so we're investigating...
Old 09-23-2018, 03:42 PM   #6
FRSBRZGT86FAN
That explains it, for my years FR-S its alot more simple
Old 09-23-2018, 08:08 PM   #7
ShansBRZ
Drives: 2017 brz
I have a diode dynamics on my 2017 with no issues. Not sure what the difference between the two would be though.
ShansBRZ is offline   Reply With Quote
Old 09-24-2018, 03:20 AM   #8
gpvecchi
gpvecchi's Avatar
One friend says that Dyode Dynamics arrival light doesn’t work on his 2018 86...
Old 09-24-2018, 05:04 PM   #9
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
I believe one of the new features for 2018 was "One Touch Signaling," which I had always assumed just meant their own, OEM version of a basic TapTurn module. However, it sounds like it might have been done at the BCM level, which would be why it suddenly doesn't play well with more advanced flasher relays...
That's my uneducated guess. Everything IS electronic these days, so it does make sense to have the turn signals controlled by the BCM, rather than by a physical relay. That allows them to easily program things like one touch signaling without changing things at the hardware level. I was actually surprised, when I went from my 1998 Outback to my 2015 BRZ, that the turn signals still utilized a mechanical flasher relay. For a car so focused on weight savings, little things like that count!
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
Old 09-25-2018, 03:24 AM   #10
gpvecchi
gpvecchi's Avatar
Nope, mine doesn’t have tap turn functionality as stock...
FS: TapTurn Flasher toeout Exterior Parts (Aero, Lighting, Etc.) 1 04-24-2017 01:12 PM
FS: TapTurn (non strobe) tracerit Interior Parts (Incl. Lighting) 1 02-15-2016 12:28 PM
TapTurn Module Number 6 Interior Parts (Incl. Lighting) 2 11-25-2013 06:36 PM
My New LED+TAPTURN=COOL KAR Cosmetic Modification (Interior/Exterior/Lighting) 0 10-09-2013 02:26 AM
FS: TapTurn module KRAZYK Interior Parts (Incl. Lighting) 6 04-25-2013 02:31 PM
