Old 09-22-2018, 02:46 PM   #1
gt86yasss
Drives: White 86
2017 EU BRZ in US?
I used to use Openflash tablet and it read the calibration code as ZA1JK00C which I believe is USDM, but when I switch to ECUtek it reads ZA1JK00G and it said it's a EU BRZ Is it common?
gt86yasss is offline   Reply With Quote
Old 09-22-2018, 07:26 PM   #2
steve99
normal
all the 2017+ manual tunes are based on the K00G ecu base
Old 09-22-2018, 10:12 PM   #3
gt86yasss
Drives: White 86
normal
Thanks Steve, was panicking for giving my tuner a wrong calibration code
Old 09-22-2018, 10:30 PM   #4
steve99
You tuner could tune it using the original calibration K00C or the alternate K00G
Old 09-23-2018, 08:57 AM   #5
Spec C Wannabe
Drives: 2017 WRB M/T BRZ
Then how can OFT allow different calibration to be flashed to an ECU?
How can they do without bricking the ECU?
Spec C Wannabe is offline   Reply With Quote
Old 09-23-2018, 10:13 AM   #6
tomm.brz
Drives: brz 2017 hksv2
you never brick the ecu even if you flash a different cal id, worst car doesnt start but you can always force a reflash
oft is a bit stupid, he doesnt notice when roms are hacked so if you hack a K00G to show like a K00C, oft just thinks that it is a real K00C, even if it s in reality is a K00G
Old 09-23-2018, 07:13 PM   #7
steve99
The oft cgecks the ecu calibration id strings in roms and compares them to the original calid strings on the rom it read into itself when it was married to car. If the id strings dont match oft wont load roms into the oft
This is to stop people flashing incorrect roms to cars. like trying to load a nissan rom to an oft married to a brz.
However oft only checks 2 of fhe three calid strings, so its possible to fool the oft into loading different calids but you need too alter roms with hex editor. Not something you want to do unless you know exactly what your doing and that the rom your modifyibg is compatable with car
Auto roms dont work in manuals and some calid from newer cars are not compatable with older ones
If the rom is a brz\86 rom and its not corrupted it wont brick ecu, but if its corrupted or not from a brz\86 its possible to brick the ecu.
It should be recoverable if you have correct tools but sometimes not ann easy process
Old 09-29-2018, 11:14 AM   #8
gt86yasss
Drives: White 86
Just ran into a similar problem. The shop who helped me install the supercharger loaded the SC map onto the ECU before they unload the OFT map, and now I can't un-marry the tablet from my car. If I reload the stock map stored in the OFT, will it erase the ECUtek license on my car? And will it cause any problem for using a OFT stock map to overwrite a ECUtek map, and then overwrite the OFT stock map with a ECUtek map again?
Old 09-29-2018, 12:22 PM   #9
tomm.brz
you are screwed, you would lose ecutek license if that would work which i dont think so, anyway the OFT you have now is bricked so you would have to send back to Shiv or steve in australia to unbrick it
Old 09-29-2018, 10:17 PM   #10
gt86yasss
Drives: White 86
I hope what you and I are thinking is wrong. Will contact the shop ad Shiv and see what they say
Old 09-30-2018, 01:17 AM   #11
steve99
Unfortunatly tom brz is correct.
Ecutek embedds licoence in ecu. If you overerite ecutek fladhed cars with any otjer tuning device other than ecutek then licience is lost.
The oft cannpt write to ecutek tuned cars unless you flash back stock map with ecutek to unlock the ecu from the ecutek lock.
The only way out is for your tuner to ask ecutek if they will renew your ecutek licience if you write over it with oft.
CSCS Mid Summer DRIFT 2017 - Round 3 - SUN July 23 2017 @ TMP CAYUGA SB LAYOUT DTrouble CANADA 0 07-19-2017 08:42 PM
2017 CHRYSLER PACIFICA MINIVAN VS 2017 TOYOTA 86 WHO WINS IN A DRAG RACE??? Extreme Dimensions Off-Topic Lounge [WARNING: NO POLITICS] 6 06-08-2017 08:59 AM
Boost Festival 2017: Feb 25, 2017 Willow Springs GTA, JustDrift, Drift ModinJapan Southern California 1 01-25-2017 12:46 AM
2017 Acura NSX vs. 2017 Nissan GT-R JPxM0Dz Other Vehicles & General Automotive Discussions 1 10-19-2016 01:50 PM
Controlling the nannies in 2017 vs. pre 2017 mdm Scion FR-S / Toyota 86 GT86 General Forum 23 10-04-2016 11:11 PM
