Old 09-17-2018, 03:36 PM   #1
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Oh, you upgraded to Hella Horns? That's cute...
Updated this post with this full walk-through video
[ame]https://www.youtube.com/watch?v=UjkKfxSaf8M[/ame]
------- ORIGINAL POST -------
[ame]https://www.youtube.com/watch?v=GLFWYSDhCbw[/ame]
Sooo... I got a bit carried away with my horn upgrade...
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
Old 09-17-2018, 03:43 PM   #2
"A bit"?
Old 09-17-2018, 03:44 PM   #3
Stang70Fastback
A.K.A. Starlord
"A bit"?
By, like, maybe 10%.
Old 09-17-2018, 04:18 PM   #4
ermax
ermax's Avatar
How often does the compressor run and do you hear it inside the car?
Old 09-17-2018, 04:24 PM   #5
VIP BRZ
VIP BRZ's Avatar
Drives: 2014 Subaru BRZ
Will it play the dukes of hazard tune?
VIP BRZ is offline   Reply With Quote
Old 09-17-2018, 04:31 PM   #6
Stang70Fastback
A.K.A. Starlord
The compressor is attached to a pressure sensor (that grey box) and kicks on automatically at ~110 PSI, and cuts off at 150. It's an overpowered compressor for this application, considering the size of the tank (2 gallons) so that takes less than a minute. It takes about 3-4 blasts similar to the ones you heard in the video to discharge the tank enough to trigger the compressor. I also have switches in the cabin. One of them toggles between the stock and train horns, and the other controls power to the compressor/sensor/solenoid, so the compressor won't run at all unless it's turned on. Those switches are keyed to accessory power, so they shut off automatically when the car is off.
As for noise, in normal driving, it's basically impossible to tell if the compressor is running unless you come to a stop, and then flip it off and on while listening carefully, lol. But I do have a sheet of sound deadening material that I slid behind the carpeting of the rear seats to isolate all of the road noise from the trunk area, so I'm sure that's helping to mute it.
Old 09-17-2018, 04:54 PM   #7
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
That's certainly one horny car.
Old 09-17-2018, 04:59 PM   #8
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
l...
o...
l...
cant...
breath...
Old 09-17-2018, 07:13 PM   #9
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by Stang70Fastback View Post
Jesus christ man, that's not even legal is it?
Old 09-17-2018, 07:16 PM   #10
SkyeHack
SkyeHack's Avatar
Drives: 2018 BRZ tS
Post some reaction videos now!!
Sent from my SM-G965U using Tapatalk
SkyeHack is offline   Reply With Quote
Old 09-17-2018, 07:24 PM   #11
AnotherSlowAE86
AnotherSlowAE86's Avatar
Drives: Subaru BRZ and AE86 coupe
I N T E N S E
Build Threads:
1985 AE86 Coupe /// 2014 BRZ Limited (soon.. gathering pictures)
AnotherSlowAE86 is offline   Reply With Quote
Old 09-17-2018, 07:51 PM   #12
Stang70Fastback
A.K.A. Starlord
Lol. Not REALLY. There is no hard limit in most states (at least the ones I've lived in), but there is a very vague "the horn must not be unreasonably loud" phrase in most states' codes. However, since people tend to ignore normal horns, I consider mine to be reasonable! :P
Lol. I'm not one of those assholes who drives around pranking everyone. Other than actual normal horn duty, I only honk them as a party trick (or if it's someone I know, lol.)
Old 09-18-2018, 10:27 AM   #13
xenarc
xenarc's Avatar
Drives: 2017 SUBARU BRZ
Video please.
xenarc is offline   Reply With Quote
Old 09-18-2018, 10:31 AM   #14
ScoobsMcGee
Junior Senior with Cheese
ScoobsMcGee's Avatar
Does the horn create enough pressure to push the car backward? While on throttle?
DIY - Hella Supertone horns installation on FR-S driver01 DIY (Do-It-Yourself) Guides 93 07-22-2019 04:08 PM
Hella Horns. Custom colors available at B2autodesigns b2autodesigns Miscellaneous 89 09-11-2017 12:05 PM
DIY - Hella Horns olorin DIY (Do-It-Yourself) Guides 21 06-01-2017 04:59 AM
FS: NJ GrimmSpeed Hella harness/Hella Sharptones Joon525 Exterior Parts (Aero, Lighting, Etc.) 7 10-13-2016 09:42 AM
[FS] Hella Horns, Tail as Turn module Cole Canada Classifieds 77 03-04-2016 01:58 PM
