Old 09-13-2018, 01:34 PM   #1
LaitheBRZ
Drives: 2013 BRZ, 240SX S13
Quality Lug nuts for track use (drifting)
Recently picked up cosmis MR7 wheels for my car and I’m deciding on what lug nuts to go with. Looking for tuner style steel lugs. Suggestions?
LaitheBRZ is offline   Reply With Quote
Old 09-13-2018, 01:42 PM   #2
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Welcome to the forum.
Very interested in seeing some pics of your new wheels on your car. They are 18x9 +25 correct? What tires did you go with? Suspension mods?
As for lug nuts; I have had aluminum and steel. I prefer steel. I currently have open ended lug nuts for my extended studs that are 24k plated. They go with my "look"
My suggestion would be to find some that are the look you want and fit in the budget you have.
I LIKE TIRES!
Old 09-13-2018, 02:01 PM   #3
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Muteki make affordable lug nuts that do the job. Most of their products are steel, with one true titanium option. Many people have been running their products for a long time. They have a range of sizes and options at various prices. They are pretty utilitarian. Not "super lightweight, maximum precision performance" stuff, but they do the job and last a long time.
Gorilla brand lug nuts also come to mind on the affordable/utilitarian side.
Project Kics is the premium brand that comes to mind if you're willing to shell out the money. They also have the Bull lug nut line for afforadability
Many major wheel manufacturers (Rays, Work, SSR, etc) often sell lug nuts under their own company names as well.
Personally, I prefer close-ended lug nuts or open-ended lug nuts with caps. It helps keep water and debris away from the studs, making sure the threads stay clean and as rust free as possible.
Short close-ended lug nuts can sometimes be too short if you have extended studs. Also, longer lug nuts tend to be a little easier to work with since there's more room to grab them with your finger.
Depending on what organization you're doing HPDE with, there may be rules that require open-ended lug nuts so that they can inspect thread engagement depth.
EndlessAzure is offline   Reply With Quote
The Following User Says Thank You to EndlessAzure For This Useful Post:
Leonardo (09-13-2018)
Old 09-13-2018, 02:22 PM   #4
strat61caster
strat61caster's Avatar
There's nothing wrong with factory as long as the studs aren't extended.
ineedyourdiddly
Old 09-13-2018, 03:25 PM   #5
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
That pretty much covers it. Muteki are cheap and do fine. The colored ones may fade but are cheap enough to replace if it bugs you.
Old 09-13-2018, 03:54 PM   #6
ZDan
ZDan's Avatar
Drives: '23 BRZ
FT86 needs ARP wheel studs more than it needs aftermarket lug nuts...
The Following 2 Users Say Thank You to ZDan For This Useful Post:
G-Man (09-13-2018), Tristor (09-13-2018)
Airbag disable for track / drifting? deadeyes989 Tracking / Autocross / HPDE / Drifting 10 09-02-2020 04:18 PM
Replacing all 20 lug nuts. Will these be fine for track? Sachmet43 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 31 07-15-2018 07:22 AM
FS: 20 Black Wheel ACORN LUG NUTS and 5 Lock Nuts 12x1.25 and 19 MM Socket w/Sleeve neilvosko Wheels and Tires 14 06-18-2018 09:47 PM
Night Drifting Track Day July 13th-The Balcony in SoCal Louie Southern California 3 07-12-2013 02:04 AM
