Old 09-11-2018, 02:20 PM   #1
TheBRZsKnees
TheBRZsKnees's Avatar
Drives: 2014 BRZ
Gloss Clear Coat Over Caliper Stickers
I just got a new set of RR Racing Sport brakes. The brakes are great. However, by the end of the first break-in session, the stickers on the rear calipers were peeling badly. For whatever reason, the fronts held fine.
RR Racing is sending me replacement stickers. I'd like to re-apply them and add a coat of caliper clear coat.
https://www.amazon.com/VHT-SP730-Glo...dp/B000CPJLV2/
At least one person in the reviews said this worked for them. However, I'd be applying the clear coat to calipers that are already painted gloss black, rather than primed. If it doesn't hold well, I'm worried that I could end up with something that looks worse than what I started with. Does anyone have experience with a situation like this?
TheBRZsKnees is offline   Reply With Quote
Old 09-11-2018, 10:02 PM   #2
wparsons
wparsons's Avatar
Typically you'd want to scuff the existing gloss layer before the clear with like 800 grit wet sandpaper, but not sure if the high temp stuff is any different.
flickr
Old 09-11-2018, 11:37 PM   #3
humfrz
So, ph4zon, you're concerned about the stickers on the brake calipers? Do they not perform as well if the stickers are wore off? Obviously the stickers they use are not racing stickers.
(I'm jest ah messen wich ya - )
Yep, like @wparsons said, just rough up the area to be painted a bit and spray that stuff over the stickers. I'd suggest you also use alcohol to prep the area you paint.
humfrz
wparsons (09-12-2018)
Old 09-12-2018, 12:50 PM   #4
tomm.brz
Drives: brz 2017 hksv2
cover them with carpro Dlux
Old 09-12-2018, 01:02 PM   #5
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
More stickers = more brakepower.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 09-12-2018, 01:16 PM   #6
TheBRZsKnees
Drives: 2014 BRZ
The calipers were powder coated black. Wouldn't I be removing the black paint at that point?
humfrz
This \/
Is Carpro Dlux heat resistant?
As a side note, I removed the remnants of the rear stickers after a short drive last night, and noticed that the rear calipers were much hotter than the fronts. The fronts were barely warm to the touch. Not sure if this is normal.
Old 09-12-2018, 01:25 PM   #7
humfrz
This \/
What we mean by "scuff up" the surface is just to lightly take the top layer of gloss off - not all the coating.
I don't see why the rear calipers would be warmer that the front ones, if the system is working properly.
Of course, my brake knowledge is dated -
humfrz
Old 09-12-2018, 02:38 PM   #8
tomm.brz
yes dlux resist over 800F (426 celsius)
The Following User Says Thank You to tomm.brz For This Useful Post:
TheBRZsKnees (09-12-2018)
Old 09-12-2018, 04:37 PM   #9
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
I think it's because the stickers are not high temp. I have wilwood brake calipers (same as your kit) and the stickers are fine for my kit. Can't you just rip them off and apply high temp stickers?
N1rve
Old 09-12-2018, 08:39 PM   #10
TheBRZsKnees
Drives: 2014 BRZ
I'm using the RR Racing stickers, so I'm pretty much stuck with what they provided me. I haven't seen any other complaints about them, but yeah, I was able to effortlessly peel them off once the calipers were hot.
Using Wilwood stickers instead is an option. The RR Racing front stickers are fine though, so I'll see.
Old 09-12-2018, 09:21 PM   #11
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Ok... Seriously. Wtf is this fuss about stickers. Why does one need stickers on calipers?
The Following User Says Thank You to Spuds For This Useful Post:
Tcoat (09-14-2018)
Old 09-12-2018, 09:30 PM   #12
wparsons
wparsons's Avatar
If you manage to remove powder coat wet sanding with 800 grit you'd be some kind of hero.
That sounds like the rears are sticking, if anything the fronts should be much warmer.
flickr
The Following 2 Users Say Thank You to wparsons For This Useful Post:
Tcoat (09-13-2018), TheBRZsKnees (09-13-2018)
Old 09-14-2018, 12:01 AM   #13
humfrz
- because STICKERS!
Spuds, you're getten to be an old fuddy duddy -
humfrz
Spuds (09-14-2018)
Old 09-14-2018, 01:46 AM   #14
It is a proven fact that stickers on calipers increase your street cred by .087%.
Spuds (09-14-2018), wparsons (09-14-2018)
caliper, clear coat, primer, sticker
2-stage polish & Optimum Gloss Coat by Orion Detailing! l8apexr CANADA 34 12-18-2017 11:07 AM
Coated the car with Optimum Gloss-Coat kberkel Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 10-25-2014 09:43 AM
WTB: powder coat caliper core? jeffs42885 Brakes, Suspension, Chassis 2 09-15-2013 08:34 PM
Clear Coat sierra Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 06-28-2013 10:21 PM
Clear Coat Help Mr. J Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 6 12-28-2012 10:22 AM
