Old 09-08-2018, 02:09 PM   #1
sandy s
Drives: 86 gt
6speed oil change
Hello Guys Decided to change gear box oil to synthetic. Shifting was ok but synthetic will usually improve it. a few comets on the job.Take care when you remove the drain plug.It comes out at speed.Leaving the filler plug in may help. Only a little sludge on the magnet and nothing came out with the oil but the oil was pretty dirty looking.Car has 47k on it. I would have to say Toyota recommendation to not change it is somewhat suspect. And yes the shifting is much improved with the new oil. Cheers sandy in Nelson NZ
sandy s is offline   Reply With Quote
Old 09-08-2018, 02:15 PM   #2
JD001
JD001's Avatar
Drives: Subaru BRZ
Title reads 'Six Speed Oil Change', I was expecting the following:
1. Slowly raise the car.
2. Gently undo gubbins
3. Swiftly undo plug.
4. Oil gushes out.
5. Race to grab oil catch can.
6. Oil slows down as oil catch can is placed under the drain.
WTB: OEM 6speed shifter rod norcalpb Want-To-Buy Requests 3 10-03-2018 08:12 AM
FS: Stock 6speed from FRS (12k Miles) PrimeMotoring Transmission and Driveline 0 12-19-2014 10:18 AM
Tips on obtaining a 6speed? peachsnow Scion FR-S / Toyota 86 GT86 General Forum 28 10-23-2014 12:16 AM
F/S 6speed Manual Transmission C130NAV Transmission and Driveline 10 09-11-2014 08:24 AM
