Old 09-05-2018, 04:37 PM   #1
GrantedTaken
How is OEM front badge installed at factory?
Front badge fell off.
How is it installed?
A) It is taped on, and the 2 prongs just guide pins.
B) The prongs are friction fit, and hold the badge in place.
If A, what is good tape to stick it back on?
Example from stock photo
GrantedTaken is offline   Reply With Quote
Old 09-05-2018, 04:41 PM   #2
mrderp
ಠ_ಠ
mrderp's Avatar
Drives: 860 SansOverspray
3m trim tape works wonders.
mrderp is offline   Reply With Quote
Old 09-05-2018, 10:04 PM   #3
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
It's just it's own toyota equivalent of 3m automotive VHB, the pins are guide pins.
I'd use goo gone and/or a 3m eraser wheel and heat and get that area as clean as possible first. Then proceed to reinstall, also the $8 adhesion promoter sponges from 3m make a real difference on how it applies. I've had the JDM badges on my FR-S since 2015 and they show no signs of coming off following that method.
Old 09-05-2018, 10:34 PM   #4
cjd
cjd's Avatar
Drives: 2017 BRZ
I believe there are friction-fit clips over the pins on the underside of the bumper cover (can make it a bit of a pain to remove). Most people that change badges out simply use the 3m tape.
is there a oil temp sensor installed from factory? nEEdLzZz BRZ First-Gen (2012+) — General Topics 16 09-14-2019 06:23 PM
Factory BRZ Front brake calipers and brackets with speed blenders installed. Joesurf79 Brakes, Suspension, Chassis 5 07-25-2018 10:16 PM
Factory Subwoofer Installed go2brz BRZ First-Gen (2012+) — General Topics 0 07-19-2013 09:14 PM
BRZ limited has factory installed sound proofing ebgs500e BRZ First-Gen (2012+) — General Topics 36 05-27-2013 09:01 AM
Removing the 86 badge on the front of the car Pake1 Cosmetic Modification (Interior/Exterior/Lighting) 1 06-10-2012 08:37 AM
