Old 08-31-2018, 10:13 PM   #1
RenzZn6
Drives: 2015 Scion FRS
Jdm GT86 headlights on halogen FRS
Just bought a pair of gt86 headlights and was wondering if anyone has ever put them in the halogen 86s since they have different wiring, already looked at the DIY but there’s says they had 7 pins on there 8 pin connectors, but my JDM have 6 pins on a 8 pin connector. Anyone ever done this??
RenzZn6 is offline   Reply With Quote
Old 08-31-2018, 10:29 PM   #2
Cothman4Life
Drives: 2016 VW Golf, 2017 Toyota 86
So I had to rewire my 86 because the spec D was only made for the frs. I would believe it is the only to do so if you wanted to put an 86 headlight into the frs. I had to cut the plug from the OEM and the spec D headlight and do some soldering to match up each wire to matching wire to make it still plug and play.
Sent from my Pixel 2 XL using Tapatalk
Cothman4Life is offline   Reply With Quote
Old 08-31-2018, 10:50 PM   #3
RenzZn6
Do you have pictures of it?
FS: Scion FRS Headlights Halogen $175 dem00n NY / NJ / CT / PA 0 05-05-2018 05:24 PM
changing from 2015 jdm gt86 headlights to frs headlights 420zn6 Cosmetic Modification (Interior/Exterior/Lighting) 9 12-16-2016 04:18 PM
brz with gt86 headlights RaineyStar Cosmetic Modification (Interior/Exterior/Lighting) 0 12-09-2014 02:15 AM
GT86 headlights vs. Maserati Ghibli Headlights l0aded Scion FR-S / Toyota 86 GT86 General Forum 7 08-29-2014 08:39 AM
Halogen manual leveling works with edm/jdm HID headlights ? adprokid Cosmetic Modification (Interior/Exterior/Lighting) 0 07-03-2012 12:32 PM
