Old 08-30-2018, 07:12 AM   #1
Adreen77
Drives: White turbo 86
Rough idle after reflash tune
Hi guys, kinda need help here. I own a 2012 86. Engine running turbo. Changed clutch and pulleys. It has been tuned before with ecutek. On a recent tune, i decided to retune it again based on a forum chat here on the annoying idling sound. So now after reflash the car seems to misfire, i can hear feom the exhaust that 1 piston is not firing properly. But during driving and blasted it was fine. Only the throttle feels slightly hestated. I have replaced my spark plugs and coils to trouble shoot but none seems to solve it. Theres no CEL warning on it as well.
Adreen77 is offline   Reply With Quote
Old 08-30-2018, 08:18 AM   #2
steve99
First thing to do would be flash back the turbo tune that worked, before you altered tune with your changes
Old 08-30-2018, 09:43 AM   #3
Adreen77
right after the idle went nuts, i tried reflash back to the previous tune. start it back up, same issue again.
Old 08-30-2018, 06:06 PM   #4
steve99
Ok
Keep the original tune in, then do some logging
Check your ltft at idle should ve less than 10% if its way positive you probavly got exhaust or intake leak,cgeck the hoses under intake manifold are clamped on
Cgeck idle manifold pressure it should ve about 0.3 bar with engine running
With engine stopped should be 1 bar
Check afr at idle should be close to 14.7
Ignition timing at idle once warm should be arround 11-13 degrees
Old 09-03-2018, 07:35 AM   #5
Adreen77
I havent tried any as my tuner is out of town and basically i am waiting for my buddy to check using his obdii scanner. For now as i remembered i asked him to do the things as attached
Took my car in for rough idle... Da Brz Issues | Warranty | Recalls / TSB 34 10-29-2016 12:57 AM
'14 BRZ Ltd. - Rough Idle leicaboss BRZ First-Gen (2012+) — General Topics 20 05-22-2014 06:40 PM
Scion FR-S, Subaru BRZ rough idle issues require ECU reflash gunitrecord BRZ First-Gen (2012+) — General Topics 1 10-06-2012 02:14 AM
Looks like CEL/Rough Idle is getting a lot more attention. wawro569 Scion FR-S / Toyota 86 GT86 General Forum 11 10-06-2012 12:24 AM
Rough Idle & CEL *video JiB Issues | Warranty | Recalls / TSB 5 10-04-2012 10:28 PM
