Old 08-29-2018, 10:56 PM   #1
carlovestela
Drives: 2015 Firestorm FRS
Are 2017 BRZ headlights can fit to 2015 FRS? Thanks
As title. Thanks guys
carlovestela is offline   Reply With Quote
Old 08-30-2018, 01:36 AM   #2
Bach415
Bach415's Avatar
Drives: Whiteout FRS
Short answer: Yes
Long answer: Yes. They are the same size as all current headlights. BRZ headlights then to have a plastic tab that you can remove to make it look cleaner after the swap. To get it working properly (electrical-wise) you will need to do some re-pinning of the wires on either the engine harness side or the headlight harness side. You may need new connectors to make it work as well. Splicing may be needed to get the signals to work.
Bach415 is offline   Reply With Quote
Old 08-30-2018, 03:37 AM   #3
carlovestela
Thanks.
Looks like alot of work to do.
Originally Posted by Bach415 View Post
Short answer: Yes
2017 86 Headlights to 2014 FR-S OEM HID Headlights Jollibee86 Electronics | Audio | NAV | Infotainment 3 01-03-2020 07:28 PM
Are 2017 BRZ headlights can fit to 215 FRS? Thanks carlovestela Cosmetic Modification (Interior/Exterior/Lighting) 0 08-29-2018 10:55 PM
2017-18 Brz headlights shaynek Want-To-Buy Requests 0 07-31-2018 07:19 PM
2017+ Headlights on FR-S Jeff86 Cosmetic Modification (Interior/Exterior/Lighting) 3 04-25-2018 01:21 AM
changing from 2015 jdm gt86 headlights to frs headlights 420zn6 Cosmetic Modification (Interior/Exterior/Lighting) 9 12-16-2016 04:18 PM
