Old 08-28-2018, 05:13 PM   #1
BigDaddyD ABB
Drives: 2013 Brz
Post Can you help me?
I currently own a stock 2013 Subaru BRZ. My goal is make 550hp+ using a turbocharger. I am quite new to this type of stuff however I do have some background knowledge. If you could please help me by listing the needed parts and tools required to meet my goal, it would be very much appreciated.
BigDaddyD ABB is offline   Reply With Quote
Old 08-28-2018, 05:21 PM   #2
agill
Drives: '15 frs turbo
Basics: turbo kit, built engine, clutch/flywheel, fuel pump and lines, tune.
Extras: drive shaft, brakes, suspension, oil cooler, catch can or aos, trans depending on how it’s driven, wheels/tires
Something more helpful than all of that though, you can search and find this info all over the site. I feel like this topic has been talked about at least a million and a half times. There is tons of great info if you search, and you’ll probably find an answer to all of your questions. All in though you’re looking at a 20k+ budget easy imo
agill is offline   Reply With Quote
Old 08-28-2018, 05:24 PM   #3
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
A spare engine is something I'd have laying around if I planned to hit those number. Good luck!
MS, CSCS, TSAC-F, CPT
Old 08-28-2018, 05:27 PM   #4
BigDaddyD ABB
Drives: 2013 Brz
Thank You!
Old 08-28-2018, 05:30 PM   #5
agill
+one on the spare engine
Old 08-28-2018, 06:10 PM   #6
Build engine.
Big turbo.
Built transmission.
Driveshaft
Axles
Tires (to put the power down).
550+hp, realistically, will take 15k+
Leonardo (08-28-2018), x808drifter (08-29-2018)
Old 08-28-2018, 06:36 PM   #7
Leonardo
Country Boy 4 Life
Leonardo's Avatar
^ These guys know what they are talking about.
How did you arrive at "550hp" as your goal? Will you be racing your car?
I LIKE TIRES!
Old 08-28-2018, 06:43 PM   #8
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
being "new at this" and wanting 3 times the stock HP with FI don't seem like a good mix unless OP has a bunch of money laying around to pay someone else to do it in which case why didn't he just call a local shop?
HKz is offline   Reply With Quote
Old 08-28-2018, 10:11 PM   #9
Hags86
Drives: Toyota GTS 86
Build engine.
Big turbo.
Built transmission.
Driveshaft
Axles
Driveshaft? Didn't know this was an issue.
100% agree with the rest of the list. Add a clutch.
2013 Toyota 86: 275rwkW
Coyoda Water-to-air Intercooled Turbo with GTX2863. CP Carillo Rods and Pistons. Motec M150 ECU. Motec C125 Dash. Holinger SG 6 Speed Sequential Gearbox. OS Giken LSD. MCA Reds Coilover. AP Racing Essex Sprint Front Brakes. PWR Radiator and Intercooler heat exchanger.
Hags86 is offline   Reply With Quote
Old 08-28-2018, 11:35 PM   #10
sid94
Drives: 2013 frs
Im around that power and I’ve spent around 10k but I did build my engine myself and did all the work myself except the boring/machining process.
Turbo kit
Fuel system/e85
Built engine
Good clutch/clutch fork
Catch can
Prayers that your trans doesn’t pop
The axles/shafts/tires are up to you if you wanna put the power down or enjoy breaking/spinning tires
sid94 is offline   Reply With Quote
