Old 08-28-2018, 02:18 AM   #1
KooshaS
Drives: 2017 Subaru BRZ Premium
BRZ Headlight Question
Hello all! I'm new to the forums and have recently purchased a 2017 BRZ from an auction and I'm fixing it up and plan on keeping it for as long as possible. So I have the the left headlight but the right headlight doesn't have the bracket or housing. I have the actual headlight but need the black housing with all the wiring and everything. My local dealer quotes me $850 for one headlight assembly so thats my last resort. I know 2017 had a design change so I was wondering can I just buy a previous gen BRZ (2013-2016) headlight and use the housing on that or will it not work properly? I can't find any used parts for 2017 and up and if I do, its been damaged too much. Thanks for any advice.
KooshaS is offline   Reply With Quote
Old 08-28-2018, 02:23 AM   #2
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
As long as the electronics are intact and such. I'm pretty sure any aftermarket bracket or housing that fits the BR-Z will help you as well. I'm thinking finding a used aftermarket spyder, winjet headlight for the brz or the like and removing parts from it to install on another. I think the only difference in the internals. This is because I've seen people put the 2017 headlights on the 2016s
Old 08-28-2018, 02:29 AM   #3
KooshaS
That's what I was thinking but wasn't sure. Theres this guy thats selling a set of headlights from his 2014 BRZ I believe for $200. I don't want to buy it and then have it not fit or work so I just want to double check or see if theres any other alternatives.
Old 08-28-2018, 02:33 AM   #4
FRSBRZGT86FAN
$200 is very cheap, probably cheaper than an aftermarket alternative. I'm also not sure how different the connectors are or electrical stuff is if permanent. Might be a full assembly and maybe best to just bite the bullet from subaru.
Old 08-28-2018, 02:57 AM   #5
KooshaS
Thanks for the advice. Im going to go look at it tomorrow at the body shop to see what i can do
Headlight film question ARTBRZ Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 7 10-26-2016 02:40 PM
WINJET Headlight Question HATED1 Cosmetic Modification (Interior/Exterior/Lighting) 5 10-12-2015 03:46 AM
Spec-D Headlight Question iStanley Cosmetic Modification (Interior/Exterior/Lighting) 2 05-10-2014 06:44 AM
headlight wiring question Lydin Cosmetic Modification (Interior/Exterior/Lighting) 0 04-11-2014 10:02 PM
ANOTHER FR-S Headlight Question. 636 Scion FR-S / Toyota 86 GT86 General Forum 8 07-28-2012 12:31 PM
