Old 08-25-2018, 04:21 PM   #1
dynomite619
dynomite619's Avatar
Drives: 2016 subaru brz insta@black.xira
dash cluster question?
so i had an issue of a fuse blowing out and ended taking it to the dealership and they ended up find a wire grounding out but at the time i had put a higher fuse amp and end up shorting my dash, i have decline repair at the dealer to replace the dash cluster.i took it apart try see any burnt or and indication i can find to replace what needs to be done have it working but didnt see anything unusual so i have found a dash cluster on ebay looks just alike the one i have will that dash cluster work or there a part number i need look for or they all the same i have a 2016 subaru brz.
dynomite619 is offline   Reply With Quote
Old 08-26-2018, 12:19 AM   #2
dynomite619
Did some research that if u get a used dash cluster you would have to get it program or clone to the other one
Old 08-26-2018, 09:48 AM   #3
stevesnj
stevesnj's Avatar
Look in the member classified section.
My 2016 Build thread
Old 08-27-2018, 09:16 AM   #4
steve99
If you have a push button start car the dash clusters are swap and go.
If you have a key start you will need dealer to re sync security before car will start again
Old 09-01-2018, 10:54 AM   #5
dynomite619
Yes I have push start button . And the car starts without the dash cluster . And I gave it to the dealer so they can program the cluster and 2 process of programming the car .
Old 09-01-2018, 07:49 PM   #6
steve99
You don't need dealer if your car is push button start, just plug in new cluster and your good to go no resync or programming required.
Old 09-04-2018, 02:23 PM   #7
dynomite619
I plug in the new one and it does the same thing as the old one ? Like the gauges don’t turn on it displays nothing . Why is that
Old 09-04-2018, 03:23 PM   #8
dynomite619
So I came to a conclusion what it was due to the high input of fuse . I burnt a lead line on the fuse box /main body at this moment I’m doing repairs to the leads and install a jumper .I’m upset knowing what the dealer ship did who knows what the heck the fix they said they fix a wire touching metal And move it too the side . If this is the problem to everything I may need have talk to them wanna know what they repair exactly. they did not fix my problem and wanted me buy a new dash etc ...
Old 09-04-2018, 03:28 PM   #9
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Your car blows a 7.5A fuse. You put in a new fuse, and that also blew. Then you put in a 15A fuse, and continued to drive the car until even that fuse blew...
...and now you want to pin electrical issues on the dealership? Dude, what the fuck.
Source for anyone unfamiliar with this saga: http://www.ft86club.com/forums/showthread.php?t=129702
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
Old 09-04-2018, 09:29 PM   #10
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 09-04-2018, 10:23 PM   #11
Grady
Grady's Avatar
I Know you probalby already learned this but you never us a larger fuse to troubleshoot.
You should use a paper clip. That way the entire wire smokes and is easy to find.
Old 09-06-2018, 03:28 PM   #12
dynomite619
the dealership wanted charge me 1,400 for a dash cluster and i now remember that they fix the issue with a wire grounding out but they came to a problem where there wasnt power going to the cluster and thats what they though it was a dash cluster but i wasnt gunna pay that price for it so i declined the repair and bought a dash cluster plug it in and nothing happen no guages no power so i took over and decide pull out the fuse main and took it apart and discover a burnt circuit and that what happens when u put a higher fuse in it lmao u burn a circuit but if i didnt find the problem the dealership would took weeks finding it when i found it myself first try ops learn my lesson
Instrument cluster lighting question demariners DIY (Do-It-Yourself) Guides 4 07-26-2017 05:07 PM
CF dash and hood cluster Lorico Canada Classifieds 4 05-15-2017 09:38 PM
WTB - RHD Dash / Cluster trim - UK Futaba Want-To-Buy Requests 0 12-23-2015 12:05 AM
Question BRZ Cluster exam2300 Cosmetic Modification (Interior/Exterior/Lighting) 1 07-06-2015 02:16 PM
surprised at how much MORE i like the frs dash cluster pr086 Scion FR-S / Toyota 86 GT86 General Forum 26 12-07-2012 09:09 PM
