Old 08-24-2018, 08:40 PM   #1
Prmspen
Student Driver
Prmspen's Avatar
Drives: 2016 Subaru BRZ Limited
Trunk Won't Open
I can't get the trunk open on my '16 BRZ. I've tried everything. It's not just hte keyless lock-out - I've tried the button on both key fobs, and the trunk open button on the dash. When I try to open the trunk, a small red light flashes on the key fob. Have any of you had this happen? Thoughts on how to fix it?
Prmspen is offline   Reply With Quote
Old 08-24-2018, 08:45 PM   #2
dreroc-z
Drives: 1989 Camaro IROC Z28
Wait didja try the button on the left side of your trunk? Just happened to me the other day with my hands full of groceries. Had to use my physical key to unlock it...something rolled around in my trunk and hit the button.
dreroc-z is offline   Reply With Quote
Old 08-24-2018, 10:29 PM   #3
Prmspen
Student Driver
Prmspen's Avatar
Yep, that did it. Looks like I hit the button when I threw my bag in there after work.
Thanks for the tip. I feel like an idiot for not figuring that out. Not sure I understand the purpose of that lockout button, TBH. Maybe I'm just having a dim Friday...
Old 08-24-2018, 11:18 PM   #4
dreroc-z
No sweat dude I had to go into my manual. Threw me for loop aswell. It turns your trunk into a safe, basically.
Old 08-24-2018, 11:28 PM   #5
Brink
Drives: 2017 BRZ
Basically it's so you can give the valet the electronic key and keep the physical key for yourself so the trunk is still secure, if you're using a valet ever.
Brink is offline   Reply With Quote
Old 08-25-2018, 12:12 AM   #6
extrashaky
Drives: 2014 BRZ Limited
No, it's a common question here. Don't worry about it.
The lockout function is stupid anyway. The idea is that you can lock your valuables in the trunk and hit that button to disable anything but the mechanical key. But you can also get into the trunk extremely easily through the back seat without the mechanical key just by pulling up the covers on the corners and yanking up the latch rods. If a valet wants your crap, that button isn't going to stop him. And what's worse, he can put it all back (minus what he stole) so that it's still locked out and looks like nobody was in your trunk at all.
I'm surprised one of the vendors hasn't made a nice molded flip up cover for that switch yet. People get locked out often enough from stuff shifting around in their trunks that there would be a market for it.
Old 08-25-2018, 01:33 AM   #7
Ultramaroon
not playing cards
Ultramaroon's Avatar
Oh, we are going to be merciless at Sykart. Bring the lube.
Old 08-25-2018, 08:12 AM   #8
new2subaru
Weight Weenie
Drives: 15 FR-S
Just leave the switch plate/face. You would only have to do one of two things.
A) Cut the wires
B) Cut the wires and add a butt connector
In reality, it should have been the first "Mod" everyone does
Old 08-25-2018, 08:44 AM   #9
funwheeldrive
Have you tried opening it with the physical key?
Old 08-25-2018, 10:26 AM   #10
NCtoBRZ
Drives: 2017 Subaru BRZ PP WRB
I don’t see it as an attempt to keep valet (I would never let somebody else park my car anyway) out as it is a deterrent for a typical smash and grab opportunist thief. This typical type of thief will just smash a window out and quickly rummage through anything in the open, the glove box and the trunk.... they would hit the trunk release button, see that it doesn’t work and move on to the next car.
The same trunk lock button exists in NC and ND Miatas and the popular solution is to tape a plastic bottle cap over the button to keep it from being pressed. Personally I don’t see what the big deal is. I know the button exists... if my trunk is ever inoperable due to the button accidentally engaging, the next step is to simply use the key to open the trunk and press the button once the trunk is open.
NCtoBRZ is offline   Reply With Quote
Old 08-25-2018, 11:17 AM   #11
extrashaky
Originally Posted by NCtoBRZ View Post
I don’t see it as an attempt to keep valet (I would never let somebody else park my car anyway) out...
Page 23 of the owner's manual:
When required to leave the vehicle’s key with a parking attendant
Turn the trunk lid opener main switch off as circumstances demand.
On vehicles without a keyless access with push button start system, provide
the attendant with the valet key.
On vehicles with a keyless access with push button start system, remove the
mechanical key for your own use and provide the attendant with the access
key only.
I mean, that's why they call one of the keys a valet key.
Old 08-25-2018, 12:42 PM   #12
NCtoBRZ
key only.
I’m not debating what the manual says, I’m simply explaining what I would use the trunk switch for... hence my statement starting with “I don’t see...” As stated, if you are worried about valet getting into the trunk, they can still do so pretty easily and they won’t have to worry about being as quick about it as a smash and grab thief.
Old 08-25-2018, 01:41 PM   #13
spike021
spike021's Avatar
I’m surprised it hasn’t happened to me yet. And I’ve had all sorts of heavy things rolling around back there. ¯\_(ツ)_/¯
Instagram: @spike.grc
spike021 is offline   Reply With Quote
Old 08-25-2018, 02:30 PM   #14
extrashaky
I've had mine for almost five years now, and it only happened to me for the first time two weeks ago.
Trunk won't pop open Reflex Issues | Warranty | Recalls / TSB 36 01-02-2021 03:16 PM
Trunk will not open Hbomb Issues | Warranty | Recalls / TSB 33 06-12-2017 06:56 AM
Trunk Won't Open with Either Key Fob or Dash Trunk Release Ehokana Issues | Warranty | Recalls / TSB 15 04-08-2017 03:22 PM
Help Can't Open Trunk Xerious Scion FR-S / Toyota 86 GT86 General Forum 3 04-13-2014 09:10 PM
Trunk won't open Sparda29 Issues | Warranty | Recalls / TSB 13 01-11-2013 11:10 AM
