Old 08-22-2018, 02:58 PM   #1
Blackedout86
Drives: 2012 Toyota FT-86
Straight pipe with Stock Muffler ?
Please do forgive me if these are stupid questions. What happens if i go to a local shop and ask them to make Full Straight 2.5" pipe, 1.625" 4-1 header, except with stock axle-back. How would it sound like ? and does it gain Less power than a full straight pipe ? how bad is the drone ?
Blackedout86 is offline   Reply With Quote
Old 08-22-2018, 04:05 PM   #2
You would sound like an out of tune 10 year old Civic would be my guess.
The power change would be minor.
lantsalot (08-22-2018)
Old 08-22-2018, 04:38 PM   #3
norcalpb
norcalpb's Avatar
Farty
Old 08-22-2018, 05:30 PM   #4
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Originally Posted by norcalpb View Post
AIDS/Cancer
FTFY
Old 08-22-2018, 06:54 PM   #5
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
It'll sound quiet, like the stock axle back. I have catless header, OP, catless FP, and stock mid pipe and muffler on my car right now, sounds stock.
Trueweltall is offline   Reply With Quote
Old 08-22-2018, 07:04 PM   #6
86MLR
86MLR's Avatar
Without a resonator it will most likely be drony, maybe.
I take it the exhaust will be catless, cats knock out alot of sound.
Exhausts are a funny beast, either you like it, or don't.
You can always add a resonator at a later date.
As for power, you may lose some, you may gain some, where you lose or gain will depend on header design.
Old 08-22-2018, 07:32 PM   #7
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
I ran Tomei UEL, Motiv OP, Berk HFC front pipe, and stock catback for like a week.
I sounded like a 90s Civics with a Pepboys muffler. Not good.
Old 08-22-2018, 08:49 PM   #8
86MLR
86MLR's Avatar
I'm confused about this ELH UELH debate, everyone with the UELH on a EJ25 STI or older WRX is getting ELH for torque and hp gains, everyone with A FA20 is going for UELH for torque and hp gains.
Surely the difference between EJ and FA for the headers and subsequent gains should be typical.
From my experience, UELH have issues with the exhaust flow pulse being not efficient.
Marketing??
Old 08-22-2018, 08:53 PM   #9
finch1750
finch1750's Avatar
Marketing??
UEL helps midrange TQ. EL has better top end power.
WRX/STi has a turbo and no torque dip like our engine. Since you still gain up top on our car with UEL it isn't as much of a trade off plus you get the subie rumble sound vs your typical NA 4 banger sound with the EL.
Edit: To clarify this is a generalization. Exact headers and tuning means ymmv
norcalpb (08-22-2018)
Old 08-22-2018, 11:14 PM   #10
86MLR
86MLR's Avatar
Wouldn't a header with shorter primaries, good collector and secondarys design help the midrange, without the inherent pulse problems of a UELH?
For all my years, ensuring you had EL and correct length/diameter of your primaries/secondarys for where you want your power was always the focal point during design and fabrication.
My uncle was always going on about fluid dynamics and how important header design was.
Old 08-23-2018, 02:36 AM   #11
finch1750
finch1750's Avatar
I have no idea tbh. I just know what I gathered from dyno graphs between here and NASIOC essentially. Every UEL has different length runners from the collector affecting performance it seems and results in different results. Tomei seems to be the most "uneven" but has some of the best top end results too.
And an EL with a proper tune should help eliminate most of the dip anyway. But some EL do this better then others for whatever reason (length, diameter, etc). I'm sure it all makes a difference so just a matter of doing proper research or knowing exactly what you are doing if going DIY. Though I imagine its cheaper to let someone else like Tomei, HKS, or ACE do the R&D and just buy theirs in the end
Old 08-23-2018, 03:03 AM   #12
86MLR
86MLR's Avatar
I'm sticking to my 2017 OEM headers for now, they have a couple of mm larger diameter primaries and secondarys than pre 17 headers.
Unless of course I go turbo, which, at this stage, isn't in the picture.
Anyways, the torque dip isn't worrying me, either I'm cruising around the streets, or, if I'm up it, it's never under the rpm where the dip is anyway.
Fluid dynamics is like black magic, only with more math.
Old 08-23-2018, 11:07 AM   #13
finch1750
finch1750's Avatar
Between the improved headers and shorter FD the MY17+ really doesn't need it as bad. When I test drove one it felt just as fast as my car with headers and tune.
Old 08-23-2018, 04:00 PM   #14
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Same here except my car sounds like shit.
FS: 2.5" Venturi Inserts $12 tone down drone (catless, straight pipe, muffler delete) neilvosko Engine, Exhaust, Bolt-Ons 12 02-06-2017 11:31 AM
SPECIAL PRICE TOMEI TITANIUM MUFFLER TYPE -80,60S,60R/FRONT STRAIGHT PIPE TYPE-80,60 myjdmparts Groupbuys 15 10-08-2015 10:41 PM
WTS/WTT Stock Muffler, Front Pipe & Over Pipe Yamaha_R6 Engine, Exhaust, Bolt-Ons 10 08-25-2014 03:14 PM
