Old 08-20-2018, 05:29 PM   #1
jcb476
Release 10 Series
jcb476's Avatar
Drives: 2013 10 Series FR-S #1874
Gas Gauge
Forgive me if this has been covered in another thread in the past. As a new member, I did a search but found nothing like what I am experiencing.
I purchased a 2013 FR-S a week ago. Yesterday, I had about 3/4 of a tank of gas and I was going to top it off to full. After filling up, I got back in the car and noticed that gas gauge had not moved from the 3/4 mark to full. Has anyone else had this happen or know what might be the cause?
I am going to drive the car for a while longer to see if the gauge drops. If it does, I will then fill it up again and see if the needle points to full or not.
jcb476 is offline   Reply With Quote
Old 08-20-2018, 06:22 PM   #2
22R
22R
22R's Avatar
Drives: 2012 Camry SE 2017 Toyota 86
Happened to my 17 86 once. From what I read it is normal as it is a compensation thing so that the fuel gauge stays pretty steady so a small change it won't register. Mine never did it since but I usually always fill it at least below 3/4 tank.
22R
22R is offline   Reply With Quote
The Following User Says Thank You to 22R For This Useful Post:
Ultramaroon (08-20-2018)
Old 08-20-2018, 06:27 PM   #3
jcb476
Release 10 Series
jcb476's Avatar
Thanks 22R. Hopefully the gauge will drop as I continue to drive it, and then I will fill up the tank and see where the needle points at that point, being there will be a greater distance to move at that time.
Old 08-20-2018, 07:22 PM   #4
Ultramaroon
not playing cards
Ultramaroon's Avatar
Normal for this car. Just don't fill until below a half tank.
Old 08-20-2018, 08:46 PM   #5
stevesnj
stevesnj's Avatar
Was the car running while you were filling it or the ignition at the "on" position?
My 2016 Build thread
Old 08-20-2018, 11:59 PM   #6
jcb476
Release 10 Series
jcb476's Avatar
No, the car engine was completely off.
Old 08-21-2018, 06:15 PM   #7
metalmoses
metalmoses's Avatar
Drives: 2013 Scion FR-S Firestorm MT
I've noticed this as well on my car, it is a 2013. I've just waited until the gauge drops to 1/2 tank and you won't see the issue. Not sure why this happens on our cars
Parts List: Perrin CAI + Borla UEL Header + Perrin Overpipe + Invidia Front Pipe w/ High-Flow Catalytic Converter + FT-86 SpeedFactory V1 Exhaust + 10k HID's + Eibach Sportsline Springs + TRD Spoiler + Rear Diffuser + Rear Spats + OFT Stage 2 Tune +18" Enkei Black Raijin Wheels (18x8 +45 up front 18x9.5 +45 in rear) Tire Specs: 235/40R18 in the front, 265/35R18 in the rear
metalmoses is offline   Reply With Quote
Old 08-21-2018, 06:24 PM   #8
jcb476
Release 10 Series
jcb476's Avatar
Very interesting. At least I'm not alone. I will definitely wait until it drops below 1/2 to fill. Until then, until the tank drops below 3/4, it will look like I'm getting GREAT gas mileage.
Old 08-21-2018, 06:57 PM   #9
extrashaky
Drives: 2014 BRZ Limited
Because these cars are built for violent lateral maneuvers that slosh the gas around in the tank and would make your fuel gauge bob up and down like a cheerleader's head on prom night if it wasn't designed to dampen out small changes in level.
The Following 2 Users Say Thank You to extrashaky For This Useful Post:
g e (08-21-2018), metalmoses (08-22-2018)
Old 08-28-2018, 01:29 PM   #10
02.ACCORD.DUDE
Car N00B
Drives: Honda Accord (2002)
While on the topic of the gas gauge... How much is typically left in the tank when the gas light comes on?
02.ACCORD.DUDE is offline   Reply With Quote
Old 08-28-2018, 01:34 PM   #11
Loads.
Mine comes on pretty much weekly. Have driven as many as 30 miles after it comes on and have never run out.
Old 08-28-2018, 01:51 PM   #12
02.ACCORD.DUDE
Car N00B
Loads.
I think I've hit around 40-50, I was just curious if anyone had an "exact'er" number as I'm going to be traveling to Canada this weekend and who knows how many miles I'm going to have to drive to get gas when there
Old 08-28-2018, 01:56 PM   #13
The consensus seems to be about 3 gallons remain when the light comes on.
Where are you going in Canada? You realize we have gas stations all over just like you do right?
Old 08-28-2018, 02:02 PM   #14
02.ACCORD.DUDE
Car N00B
Haha of course, I was just pulling your leg. I've been numerous times before - just never drove the distance in the FR-S.
AEM Oil temperature gauge and pressure gauge with pods. mtsound Engine, Exhaust, Bolt-Ons 2 08-24-2017 12:55 PM
Fs: Gauge Pod and Autometer Boost Gauge Juanito08 Interior Parts (Incl. Lighting) 1 06-29-2017 04:36 PM
Gauge cluster with Oil Temp Gauge Jetbill Interior Parts (Incl. Lighting) 1 10-06-2015 01:41 PM
Defi Oil Pressure Gauge and Cravenspeed Flexpod Gauge Mount Install and Review Tye300 Cosmetic Modification (Interior/Exterior/Lighting) 10 05-22-2015 12:48 PM
Temperature Gauge a dummy gauge? bambbrose BRZ First-Gen (2012+) — General Topics 40 08-19-2012 04:29 PM
