Old 08-20-2018, 05:27 PM   #1
gt7877
Drives: turbo frs
EcuTek tuning required
dear
i have turbo frs tuned by ecutek can anyone help me to retune it with stock injectors
cozeit was tuned with 720cc injectors and one of them no doesnt work good
so i have to re tune it again
i have ecutek cable and proecu program
could anyone helpp me ?
my tuner refuse to tune it for personal reasons
thnx
gt7877 is offline   Reply With Quote
Old 08-21-2018, 03:01 AM   #2
steve99
Originally Posted by gt7877 View Post
dear
thnx
I gather its a turbo or supercharged car.
if so the stock injectors will likely not flow enough fuel so it cannot be tuned on stock injectors,
unless you are removing the turbo/supercharger
Old 08-21-2018, 07:45 AM   #3
gt7877
Drives: turbo frs
Its turbo car
Custom made
Turbo size 60
samy sbd style turbo kit
Ok if i install new 850cc injectorz
Anyone can help ?
Thnx
Old 08-21-2018, 08:14 AM   #4
churchx
churchx's Avatar
Drives: 2014 GT86
Just like with stock injectors there might be not enough fuel, with even larger then current injectors i guess there might be issue of too much fuel if with very same tune. You cannot get/buy 720cc like one that doesn't work properly if you cannot get car retuned?
Old 08-21-2018, 01:59 PM   #5
gt7877
Drives: turbo frs
Coze 720cc from ebay seller
And ot was re manufactors
So no 720cc new at markit
What u think guys
What size i have to instal ??
Thnx alot for your fast answer
Old 08-21-2018, 02:17 PM   #6
gt7877
Drives: turbo frs
What if i install 700c
Or 750cc
Wich one well be good for same tune ?
Old 08-21-2018, 05:48 PM   #7
steve99
Or 750cc
If the car was tuned on 750 cc injectors then you would need to replace with same 750 cc injectors else it will alter the fueling and likely damage engine.
Ecutek tunes are locked
Ecutek retail kits dont allow reading of ecu tune from ecu
If your tuner sent you a copy of tune to flash and its unlocked then you may be able to alter the existing rune to set it up for different size injectors but close to what your running now. Ie if its tuned for 750 you could likey alter it fairly easily to accomodate 800 or 700 cc injectors.
If the only copy of tune is in your ecu then you cannot alter it and you will need to get new tune from scratch
How much boost are you running ?
Are you running petrol or e85 or flex fuel kit
Old 08-21-2018, 11:10 PM   #8
gt7877
Drives: turbo frs
Derar
I run petrol 95
Gcc
13psi
it was tuned with 720cc not 750cc.
He send me one time tuning file throw e-mail !
Can i moded ???
Or anyone can do it for me ??
If i need tune from scratch how much well cost me ??
Thnx
Old 08-22-2018, 12:15 AM   #9
churchx
churchx's Avatar
Drives: 2014 GT86
As Steve wrote. If you have copy (you have) AND if it's unlocked (not yet known). Most ecutek tuners do lock theirs though to protect their work and lock-in to their shop to some extent. In such case i'd turn to other tuners/tuning shops to get whole tune made from scratch for your (now changed) different mods (injectors) and rest of mods that are still same, if it's not possible in any way to buy for less from original tuner adjusted tune for that single change. Check eg. Delicious Tuning. I guess, as you have ecutek license embedded in your ECU now, it should be a bit cheaper.
Delicious Tuning - Q&A EcuTeK ProECU Tuning and Maps DeliciousTuning Software Tuning 1213 06-17-2025 04:02 PM
Tuning / Exhaust guidance required Subsonic AUSTRALIA 5 06-21-2018 10:30 PM
Ecutek debacle from required recall Norcalmav23 Software Tuning 18 06-16-2014 01:09 PM
Is Speed Density tuning required for under 400HP street driven cars vgi Software Tuning 35 12-03-2013 06:29 PM
