Old 08-12-2018, 01:53 PM   #1
DJ_JAZZY_DJENT
j@ckoffofalltrades
DJ_JAZZY_DJENT's Avatar
51k-throwing codes-wont idle
Bought brand new, immediately put light pulleys and drop in air cleaner,
(drove almost a year w MAF CEL on, but car pulled hard and I didn't pay much attn to it. Always 91 and 0w20 mobile 1, recently replaced the throw-out bearing and put on a new clutch and lighter flywheel, subsequently as the bearing was failing, the car began stalling. Lack of power and a handful of codes. Main code I am seeing after multiple resets and replacing 1&3 plugs/coils and a Vvt ocv solenoid, and MAF is: P0011 & P0021
and still P0102 and P0351. Toyota of van nuys wouldn't reflash my ecu either. Car starts up and runs perfect or about a minute then stalls. any ideas? Has to be sensor, ecu or a bad wire eh? if my cam chain skipped a tooth wouldn't it knock like a killer in a horror film?
DJ_JAZZY_DJENT is offline   Reply With Quote
Old 08-12-2018, 02:51 PM   #2
dutchman1
Drives: 2017 86 6-Speed
Disregard, my previous answer if you read, sorry skimmed through the post and missed a few details.
It's definitely possible you're off a tooth on the cam. One tooth they'll typically still run, just like shit. Multiple teeth and it won't run at all and you may have contact. If you suspect an ecu, dealers typically have unlocked spare ecus you can plug in to to see if the issue go away. If you can get your hands on one of those that would eliminate that issue pretty quickly.
Just to simplify the troubleshooting process I'd knock out the MAF sensor issue first. Clean the sensor (with MAF cleaner, not generic electrical cleaner), check the connection point. Verify proper resistance at the sensor (can find it in the service manual), then determine that you don't have an open or ground in the circuit. That's the simple one, I'd start there. If you do have a bad connector somewhere, this would lead you to it as well.
2017 86 set up for CS STX autocross
dutchman1 is offline   Reply With Quote
Old 08-12-2018, 10:02 PM   #3
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Check the wire on the MAF sensor harness, P0102 is still tied to maf and P0351 might be a seperate coil pack issue...
timing
AT trans throwing codes (P0700, P2757, C1294) Brandon562 Engine, Exhaust, Transmission 11 05-15-2023 06:29 AM
Keep throwing P0463 codes on low gas l0aded Issues | Warranty | Recalls / TSB 44 08-19-2021 06:02 PM
Car throwing error codes and goes into limp mode Yehia23 Issues | Warranty | Recalls / TSB 9 09-06-2018 09:28 AM
Throwing P0171 and P1170 codes B-R-Z Software Tuning 39 01-27-2018 09:56 PM
Throwing around an idea DrDuquette BRZ First-Gen (2012+) — General Topics 18 08-04-2012 08:27 AM
