Old 08-08-2018, 07:52 AM   #1
peteypops33
Drives: 2016 Subaru BRZ Limited - 6spd
Help for a header noob
I have a '16 BRZ, Perrin catback. Otherwise stock.
I want to do a tune at some point (either delicious or OFT). But I also have a header on my shopping list.
I live in CT, and so I have to do emissions occasionally. I don't want to do anything that will cause the car to not be compliant. Does that mean I need a catted header, or just a header with O2 sensor ports?
I also don't want a CEL until I get a tune.
Finally - I like the idea of the delicious tune and then playing with the pops and bangs map. But if I get a catted header will that just destroy the cat?
Thanks!
peteypops33 is offline   Reply With Quote
Old 08-08-2018, 08:17 AM   #2
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
1. get the tune with the header, not after. There's no reliable way to get rid of the CEL without a tune.
2. Even with a catted header you can throw a CEL
3. With the tune disabling the O2 sensor codes to suppress the CEL, you will get an emissions readiness error. Depending on your state you might be allowed 1 readiness error and still pass.
4. Pops/bangs and other artifacts of introducing fuel rich conditions will harm your cats, including the secondary one in the frontpipe.
Old 08-08-2018, 09:21 AM   #3
peteypops33
Thanks for the reply.
So even with a catted header like this:
http://www.ft86speedfactory.com/ft-8...l#.W2rt_VVKiUk
I would still be at risk for CELs/emissions?
Old 08-08-2018, 09:34 AM   #4
Yoshoobaroo
TRACKBREAD
Yep, the aftermarket cats just don't work as well. They sacrifice efficiency for airflow.
O2 sensor spacers can get rid of the CEL, but it's not a reliable method, and they can do funny things to your fuel trims.
Your best bet is a catless header with a proper tune. Catless + OFT should come out loud less than a catted header by itself anyway. If you want to go cheap, look into the Gruppe-S header. It's essentially a Tomei clone, so good gains. It is easily the best bang for buck for a header.
Old 08-08-2018, 11:31 AM   #5
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Thanks!
Someone correct me if I'm wrong, but even aftermarket headers that are catted aren't compliant?
http://www.ft86club.com/forums/showthread.php?t=107855
N1rve
Old 08-08-2018, 11:34 AM   #6
Yoshoobaroo
TRACKBREAD
No header is emissions compliant except for the one that comes with the car.
Old 08-08-2018, 11:40 AM   #7
N1rve
N1rve's Avatar
So it looks like OP is out of luck since he doesn't want the car to be out of compliance.
N1rve
Old 08-08-2018, 11:45 AM   #8
Yoshoobaroo
TRACKBREAD
Yep. In some states one could pass inspection without being in compliance, but that's not advisable. If you want the car emissions compliant, you have to run the stock header and frontpipe.
Old 08-08-2018, 11:52 AM   #9
peteypops33
Ok thanks for the clarification guys.
Old 08-08-2018, 03:52 PM   #10
jflogerzi
jflogerzi's Avatar
Its not hard to swap headers on this car. When you need to get smog done put old tune and headers back on. When done put aftermarket ones back on and OFT tune.
IMO JDL UEL/Tomie UEL header with OFT.
Old 08-09-2018, 12:08 AM   #11
humfrz
Thanks!
In that case, I would just go with you already have.
humfrz
Old 08-12-2018, 02:33 AM   #12
slow15frs
slow15frs's Avatar
Drives: 15 scion frs
Ct here also i have jdl el header uncatted and was tuned at efi logic
Sent from my SM-G955U using Tapatalk
2015 Scion FR-S-hot lava 6MT Perrin cai magnaflow cbe EFI LOGICS tuned 193whp
slow15frs is offline   Reply With Quote
Old 08-12-2018, 06:51 AM   #13
Lantanafrs2
Drives: 2013 frs red
I would leave it stock if you don't want to tune it.
Old 08-12-2018, 07:12 AM   #14
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
It totally depends on how horrible the emissions testing is. You'll need to ask local people to know that.
Note that it is a federal crime to remove emissions devices, like cats. The actual crime and penalty are only for removal, not for driving a car without them, so there is no real enforcement.
Some states you can pass everything without cats, some states have visual checks that make it impossible to pass if everything is not stock. Some states are in between, and depend on where you live in the state.
UEL header question (Still a noob) Timewizard Engine, Exhaust, Transmission 6 04-13-2017 02:01 AM
Oft noob ANTLAY Software Tuning 8 07-23-2015 06:57 PM
Someone Help a NOOB! Rbmonroe Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 08-02-2014 10:27 AM
Tuner-noob needs header advice g0ast Engine, Exhaust, Transmission 30 03-01-2014 06:42 PM
noob help juanam0909 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 09-28-2013 01:17 PM
