Old 08-05-2018, 03:34 PM   #1
NyX_Nick
Drives: 2013 WRB BRZ Stock, 1991 Toyota MR2
Question for those who have replaced the TOB
For those of you who have had the bad TOB from the earlier cars, when you replaced the TOB did you also replace the snout inside the transmission?
If so, do you have a part number for it? I plan on doing my TOB soon and I'd like to buy a spare snout just in-case mine is in bad shape.
NyX_Nick is offline   Reply With Quote
Old 08-05-2018, 05:30 PM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Mine wasn't that bad. A bit of 500 grit sandpaper and some red Scott brite made it good as new.
A quick google-fu would get you the part number. It's a bit pricy depends where you get it. About $120-150 is what I seen.
Old 08-05-2018, 06:12 PM   #3
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
I replaced the tob and the fork, because that can fail too. I also added a lightweight flywheel and a new clutch, but I'm weird.
Old 08-05-2018, 06:20 PM   #4
NyX_Nick
I have a clutch/flywheel and fork/pivot as well to go in. I'm just wondering about the snout now
Sent from my CLT-L04 using Tapatalk
Old 08-05-2018, 09:01 PM   #5
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
Well, better to have one and not need it than to need one and not have it.
I'll ask about their return policy just in case you don't need it.
Old 08-05-2018, 11:23 PM   #6
BFIFE22
BFIFE22's Avatar
Drives: 2013 GBS BRZ Limited
I had my throwout bearing replaced at 62K and had them replace the clutch and flywheel while they were in there. I was told the throwout bearing itself was toast but there wasn't any obvious residual damage anywhere else including the clutch
APEXi / JDL / Perrin / Grimmspeed / Tein / Hotchkis / TRD / RAYS / Michelin / Raceseng / JPM Coachworks / SWEIDIT / Carsmo / TOM's / OFT / OEM Audio
BFIFE22 is offline   Reply With Quote
Old 08-06-2018, 02:15 AM   #7
humfrz
Noted -
humfrz
Old 08-06-2018, 11:36 AM   #8
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
If it hasn't blown up yet, there is little chance that the snout has been damaged.
Just don't hit it with a hammer before re-assembly.
Old 08-06-2018, 11:54 AM   #9
ermax
ermax's Avatar
The bearing retainer is $60:
https://www.subarupartssuperstore.co...0099AA040.html
Old 08-07-2018, 10:23 AM   #10
reeves
I was concerned mine might need replacing too, but like @bcj said unless your TOB has melted or exploded, the snout will be fine.
If you do decide to replace it, don't forget the oil seal ring behind it.
reeves is offline   Reply With Quote
Question for those of you that have replaced side markers HSUBLU Northwest 4 08-28-2017 02:13 PM
A Question For Those That Have Replaced the Factory Headunit White64Goat Electronics | Audio | NAV | Infotainment 7 05-28-2015 09:56 PM
Question for those who ONLY replaced door speakers BlackyRose Electronics | Audio | NAV | Infotainment 7 08-14-2013 01:49 PM
I may have had the first ever manufacturer-replaced FR-S VZ86 Scion FR-S / Toyota 86 GT86 General Forum 12 05-13-2012 12:39 AM
