Old 08-03-2018, 09:03 PM   #1
scottryan
Financial Distress
scottryan's Avatar
Drives: 2017 GT86 325WHP
How well does 18x9.5 fit on the front?
Anyone here run 9.5 width on their fronts? I'm trying to go square so I can rotate my wheels and was wondering if there are any issues that arise when running a 9.5 in the front.
Will be using Tein coilovers, not planning on making it low as hell.
Thanks!
scottryan is offline   Reply With Quote
Old 08-03-2018, 11:18 PM   #2
tyler_win_photo
tyler_win_photo's Avatar
Yes people do run 9.5 in the front. Depends on offset if you will have issues. You might rub depending on how low you are, your offset, and tire size.
tyler_win_photo is offline   Reply With Quote
Old 08-04-2018, 04:43 AM   #3
Towelly
Drives: MY15 Subaru BRZ
I run 18x9.5 +40 245/40 tyres without any scrubbing issues at all. It scrubbed on full lock when i first installed them but the car had toe out after fitting coil overs. after the wheel alignment no issues what so ever.
Towelly is offline   Reply With Quote
Old 08-04-2018, 06:08 AM   #4
vadim.totskyy
Drives: GT86
I have Tein Flex A, 18x9.5 Rays with 245/40 MPS4. only slightly lowered, like 1.5"
No problems at all (with coilovers).
Rotation is a good idea, I notice fronts wear out a bit quicker than rears.
Sent from my SM-G930F using Tapatalk
vadim.totskyy is offline   Reply With Quote
Old 08-05-2018, 09:49 AM   #5
scottryan
Financial Distress
scottryan's Avatar
Sounds good, and in terms of being low the car isn't going to be crazy low, I'm going for functionality over looks so the wheels gotta clear. Thanks for the response!
Old 08-05-2018, 09:52 AM   #6
scottryan
Financial Distress
scottryan's Avatar
That's good to know, I was planning on doing at least 265 all around. I care more about tire size than lowness so as long as I get it to fit without any rubbing I'll be happy, thanks for the response!
Old 08-05-2018, 09:53 AM   #7
scottryan
Financial Distress
scottryan's Avatar
Sweet man thanks for the pics, car looks amazing with those Rays
Old 08-06-2018, 03:42 PM   #8
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
I have Tein Flex A with Work Emotion Kiwami 18X9.5 +38 255 35 R18 MPS4. No issues fitting, however I have read on the meaty tire thread that 265 does rub in the rear.
On 255 35 R18, no issues with rubbing for the most power EXCEPT when I make a right turn into a driveway, the compression causes it to rub on the Driver Side Rear Bumper corner.
My alignment specs are -1.0 Camber 0 Toe Front, -1.1 Camber Rear 0.08 Toe-In Rear. I have SPC LCAs to align the rear.
Running -1.0 camber or close in the front causes the tire to stick out a lot, I'd recommend around 1.4~1.5.
N1rve
enkei, fitment, rpf1
Wheel Directory: Volk Racing TE37 18x9.0 +45 Front / 18x9.5 +40 OmegaKnight Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 05-03-2016 08:09 AM
** Volk TE37SL 18x9.5 +40 (Rear) 18x9 +45 (Front)** SOURCE,LLC Wheels and Tires 23 09-17-2013 09:25 PM
18x9,5 + 28 in front? grostoine Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 09-15-2013 04:17 PM
18x9.5 +45 (square) VS 18x9.5 +35 Front 18x8.5 +40 Rear (staggered) Funky Fresh Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 42 05-07-2013 09:52 AM
18x9.5 front? Flako Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 03-27-2013 01:30 PM
