Old 07-28-2018, 01:34 AM   #1
slyphen
Drives: Man
Send a message via AIM to slyphen Send a message via Yahoo to slyphen
rumble noise and vibration from driver side rear
Car is having a little issue. Could use some help diagnosing. Thanks in advance for the help!
Issue: feels like I'm running over cables or small rumble strips. Sound and feel like coming from rear driver side.
Frequency: often, almost 100% replicable at highway speed.
Occurance: prominent when off throttle slowing down, gets muffled a bit when on brakes, the frequency of "bouncing" is lower at lower speeds (occured as low as 5mph).
Diagnosis attempted so far: swapped wheels/tires, no OPR present on previous tires. Tightened lugnuts. No obvious damage or visual cue.
When it started happening: after Track Night. It wasn't as prominent, I thought lugnut was loose, but it wasn't. It got significantly worse tonight.
Next step: tighten all linkages, including shock nut of rear struct...
[ame]https://www.youtube.com/watch?v=ftz-Q_fwlig[/ame]
slyphen is offline   Reply With Quote
Old 07-28-2018, 07:20 AM   #2
BRZnut
Drives: BRZ DGM Limited
Could it be from the trunk area where the spare is kept?
Old 07-28-2018, 07:25 AM   #3
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
My guess, lose underbody panels and or fender liners.
Did you happen to go off track, or hit a deep pot hole?
Old 07-28-2018, 03:19 PM   #4
slyphen
Drives: Man
did not go off track, no under body panel hanging (from the rear???) the rumble can be felt though pedals and steering wheel, so i don't think its something inside the car causing it.
Old 07-28-2018, 04:20 PM   #5
Ultramaroon
not playing cards
Ultramaroon's Avatar
If you feel it in the steering wheel and while at a crawl, I'm going to say you have a bent or out-of-balance wheel. It may also be structural failure of a tire. If the latter, you are in danger of a blowout.
I hear only rattling of some panel which I am guessing is due to wheel wobble.
Old 07-28-2018, 09:27 PM   #6
slyphen
Drives: Man
its not wheel or tire, i swapped both. rattle and vibration can be felt through steering and pedals. latest diagnosis... not sure if this is normal, but it seems like a sloppy U-Joint.
[ame]https://www.youtube.com/watch?v=YDaQy9hu_Ps[/ame]
Old 07-28-2018, 10:05 PM   #7
Ultramaroon
not playing cards
That sure sounds like the same slapping sound heard in your first clip.
Check out this section of the manual. My take is forget the dial indicator. If you can feel it give in any direction, it's toast.
DRIVE SHAFT / PROPELLER SHAFT: PROPELLER SHAFT ASSEMBLY: INSPECTION; 2013 MY FR-S [03/2012 - ]
Old 07-28-2018, 11:20 PM   #8
slyphen
Drives: Man
we tried turning the shaft by hand, there were definitely some play rotational wise before it actually actuates the diff. not sure if thats normal.
Old 07-28-2018, 11:26 PM   #9
Ultramaroon
not playing cards
That's normal gear lash. Look for failures in the u-joints themselves.
Old 07-29-2018, 01:40 AM   #10
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
Dam that vid make me to think it's maybe the lsd is toast
Old 07-30-2018, 12:29 AM   #11
slyphen
Drives: Man
so we tried to repeat what we did in the video again. same clunking. but if i turn traction control off, its smooth. lead me to think the ECU is freaking out cuz wheel is spinning but car is not going anywhere since its jacked up... probably normal? on the other hand... i haven't able to recreate the same clunks in the first video when i drove it friday night... gonna take it to my mechanic's shop sometimes this week.
Old 07-30-2018, 01:46 AM   #12
gravitylover
I had a loaner Volvo some time back that rumbled and rode roughly with spin control on but when it was off all was well.
Old 10-18-2018, 11:55 AM   #13
slyphen
Drives: Man
Issue has been fixed. Driver side rear CV joint was bad. Driven on "new" axle for over 2000 miles now, no rattle of any kind.
Old 10-18-2018, 12:05 PM   #14
Thank you! Much better when there is closure on such things.
Noise at the Driver's side of the hood. Exrald Issues | Warranty | Recalls / TSB 24 04-02-2017 04:04 AM
Clicking noise in wheel area, driver side Rabbit of Caerbonnog Issues | Warranty | Recalls / TSB 19 02-18-2015 01:59 PM
Strange pulsating noise driver side footwell TennisHsu Issues | Warranty | Recalls / TSB 11 09-08-2014 11:59 AM
Creaking/Clinking Noise from Driver Side Touge86 Issues | Warranty | Recalls / TSB 17 08-17-2013 08:20 PM
