Old 07-24-2018, 12:29 AM   #1
zeroxg35
Drives: Hot Lava FRS
Windshield fluid pump system - check valve failed
Hello,
I own a 2014 FRS - and more recently I started having issues with my driver side windshield nozzle. It was not spraying properly - and had a very weak trickle. After troubleshooting, I identified the culprit as the 3 way check valve.
Has anyone else run into this issue?
Symptoms:
- spray was weak from one side - but seemed stronger than usual on the other.
- motor pump is more audible - still in working condition
- no change in spray pattern was seen when swapping the nozzles from left to right.
Part Number: SU00302699 (*had difficulty finding as of June 2024)
Alternative Toyota Part Number: 85321-28020 (Valve, washer)
Part #29 in this diagram
zeroxg35 is offline   Reply With Quote
Old 07-24-2018, 12:43 AM   #2
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Nice diagnosis. Hope you weren't stranded somewhere.
Old 07-24-2018, 02:25 AM   #3
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Woh, my driver side nozzle has been weak as of late. Might be worth a shot on checking it out.
Old 07-24-2018, 02:36 AM   #4
humfrz
Oh, that just happens when you get older -
Just spread your feet further apart, so as you don't pee on your shoes.
humfrz
Old 07-24-2018, 03:03 AM   #5
Ultramaroon
not playing cards
Ultramaroon's Avatar
This is good stuff, @zeroxg35. Thanks for posting your experience for us.
Old 07-24-2018, 06:04 AM   #6
Boomerang
86
Boomerang's Avatar
Stick a pin down the hole to clean your pipes
Old 07-25-2018, 02:19 AM   #7
zeroxg35
Keep us posted if this resolves a progressive issue? Thankfully the part from the dealership was only ~$3.50
Old 07-25-2018, 07:02 AM   #8
new2subaru
Weight Weenie
Drives: 15 FR-S
You got that @humfrz
Old 07-25-2018, 11:47 AM   #9
humfrz
Oh, yes, I get that. Once every 6 months the urologist runs a scope up my pee pee tail into my bladder and up to my one remaining kidney, to make sure the cancer has not come back.
Yep, THAT is a weird feeling -
humfrz
Windshield washing fluid on freeway?! FR-Sky Scion FR-S / Toyota 86 GT86 General Forum 47 08-06-2017 08:48 PM
check valve behind pcv myioz86 Forced Induction 62 09-07-2016 05:15 PM
Nameless overpipe/downpipe welds failed and perrin endlink failed stockysnail Northwest 4 01-14-2016 06:27 PM
How many people have taken out the windshield wiper fluid tank? ML Engine, Exhaust, Transmission 15 04-13-2014 09:07 PM
Windshield Fluid not pumping taimysho0 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 06-12-2013 12:02 PM
