Old 07-21-2018, 10:40 PM   #1
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Mini Key Fob
Figured I'd share this here as it's a bit of an odd modification. I'm a skinny guy, and skinny guys like me hate carrying stuff in our skinny pockets. The OEM Subaru fob (at least from 2015-onward) is very pretty to look at, but also hilariously massive. My car being keyless entry with push-start, I never need to actually take the fob out of my pocket. I've also only ever needed to use the physical key once in four years of ownership - and it was the day I bought the car, in the dealership lot, because the trunk valet mode button was depressed.
So having bought a new 3D printer, I decided to see if I could make a smaller "Mini Key Fob" for my purposes. This is the result. It is 26% shorter, 32% narrower, and 52% thinner (yup, less than half as thick!) It loses the physical key, but the buttons can still be depressed through the thin skin up top (it still takes as much force as the stock fob, so there shouldn't be any accidental presses.) No more light either (I was prototyping with translucent plastic which allowed this, but this final version is printed with stronger, solid blue plastic.)
I'm quite pleased with the result! It works for my purposes, and feels SO much smaller in my pocket! Still need to figure out how to sand it to a proper finish, but it still looks decent after some basic sanding.
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
The Following 13 Users Say Thank You to Stang70Fastback For This Useful Post:
atomicalex (10-24-2018), bcj (07-22-2018), Busybee (07-21-2018), Geese1 (07-21-2018), JoeC (07-23-2018), jordan7831 (07-22-2018), Kaotic Lazagna (07-22-2018), Overdrive (07-22-2018), sid_g (07-22-2018), spike021 (07-22-2018), Swabodda (07-21-2018), tehShirt (07-22-2018), Ultramaroon (07-21-2018)
Old 07-21-2018, 11:42 PM   #2
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
That's freaking cool! There are few more tweak might needed, but overall still amazing! I have first gen style key fob, so it's smaller and lighter than current ones... but I wish for smaller key fob, so this is amazing to mod!
Old 07-22-2018, 01:48 AM   #3
Stang70Fastback
A.K.A. Starlord
What other tweaks you would want to see?
Old 07-22-2018, 01:57 AM   #4
ichitaka05
Site Moderator
ichitaka05's Avatar
Quickly I can think 2 things:
1. It's cool to see flexible and able to depress through the Lock, Unlock & other buttons... but would like to see some logos, so I know which ones I'm pushing. (if I do push it)
2. If there's a way to put the key in there, it's way way better.
First key fob is small and light as is... but if you can make smaller than this plus few tweaks, I would gladly give you my money.
Old 07-22-2018, 06:56 PM   #5
tehShirt
tehShirt's Avatar
Drives: 2014 Subaru Forester
That's awesome, good work. I'd echo ichitaka and say the lock/unlock/trunk and panic button (areas) could have embossed emblems.
tehShirt is offline   Reply With Quote
Old 07-22-2018, 10:09 PM   #6
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
It almost looks like yours is already pretty minimal in size compared to the newer style. I would venture a guess that it's close to the size of Stang's printed one.
Now, that said, if the guts are pretty much the same then you know you can transplant them into a fob like his easily enough, and he can probably do a version that has a space for the physical key to snap or wedge into place similar to the OEM fob. It would make it a little larger (add width), but you'd have the physical key on you just in case SHTF. As the saying goes, better to have it and not need it....
Stang, kudos on the work, that's pretty impressive, and the side by side comparison is crazy.
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
The Following User Says Thank You to Overdrive For This Useful Post:
ichitaka05 (07-23-2018)
Old 07-23-2018, 02:33 AM   #7
spike021
spike021's Avatar
Awesome work. Looks super cool. Might be worth using my backup for a fob like this eventually.
Also,
Maybe I'm dumb here but.. what light are you referring to? I've never noticed a light on my fob.
Instagram: @spike.grc
spike021 is offline   Reply With Quote
Old 07-23-2018, 09:51 AM   #8
tehShirt
tehShirt's Avatar
Top left of the lock button, the little circle is the light.
Old 07-23-2018, 10:26 AM   #9
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Amazing work, nice job.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 07-23-2018, 12:52 PM   #10
spike021
spike021's Avatar
Oh nice. Mine's never lit up.
Old 08-24-2018, 11:53 AM   #11
Drambeenie
Drambeenie's Avatar
Drives: Black 17 BRZ LT MT PP
Any update on this?
Drambeenie is offline   Reply With Quote
Old 08-24-2018, 12:07 PM   #12
tacos
Drives: 09 impreza, 01 crv, 17 brz PP
Originally Posted by Drambeenie View Post
Any update on this?
Stang70 x Drambeenie collab?
tacos is offline   Reply With Quote
Old 08-24-2018, 12:21 PM   #13
Stang70Fastback
A.K.A. Starlord
Any update on this?
It works well for me! I tweaked the inside to be compatible with more years, as it turns out later years have a different chip layout to support things like remote start. I also changed to black plastic, and PETG, rather than PLA so that it would be more heat resistant (PLA tended to warp in the sun on a hot day.) Lastly I doubled the top layer thickness as the buttons were a bit TOO easy to press, and because I wanted it to have better long-term durability.
It still isn't the prettiest thing in the world, but it gets the job done and is much more pleasant to have in my pocket
Dunno if these Facebook images will display or not, but this is what it now looks like straight off the printer.
The Following User Says Thank You to Stang70Fastback For This Useful Post:
tehShirt (08-24-2018)
Old 08-24-2018, 03:04 PM   #14
tehShirt
tehShirt's Avatar
What are your thoughts on reusing the buttons and membrane? Shouldn't increase the height much and you wouldn't have to deal with durability/accidental button presses.
A MINI FR-S Story VittorioS Member's Car Journals 37 12-14-2017 01:43 AM
Mini-me BRZ shiumai BRZ First-Gen (2012+) — General Topics 9 08-15-2014 03:55 PM
Mini NSX M-17 Other Vehicles & General Automotive Discussions 43 11-09-2012 10:10 AM
My Mini FR-S Supermassive Off-Topic Lounge [WARNING: NO POLITICS] 13 08-23-2012 01:53 PM
What about that 1.5L Mini FT? LexusFman Scion FR-S / Toyota 86 GT86 General Forum 39 04-10-2011 09:54 PM
