Drives: Yellow FR-S Rs 1.0
P0103 (MAF code) CEL
Hi Everyone,
For the past couple of months, I have been experiencing some kind of boost/fuel cut off issue when hitting boost around 4 psi. Since the issue was never consistent, it always appeared and then went away after turning off and turning on the car. I thought it was a fuel pump issue but it looks like that my fuel rail pressure is all good, and also the car is not misfiring. Within the past month, I have experienced this twice but this time I have been getting a CEL with the p0103 code. After I clear the code, it will still hiccup a bit, but then it fixes it self until it happens again in couple of weeks. When looking at the logs my tuner had pointed out that my maf sensor was freaking out sometimes for a split second that it would 5v. I have the sbd 500x kit installed with an ecutek tune tuned for 10 psi. Only pattern that I have been seeing so far is that this usually happens the day of or the next day, after I have been driving in heavy rain and going through rain puddles. I have opened my hood to see if there are massive water spots on the filter or in my engine bay, but could not really find anything that caught my eye. My tuner did mention it could be an electrical/wiring issue. Only aftermarket part that I have related to electrical stuff is the valeni revo tailights, and the scanguage 2 connected to the obd2 to read boost, afr etc... I am not quite sure where to start other than probably clean the maf sensor or replace the maf sensor. I was wondering if anyone else is having the issue, or have any suggestions on what it could be. I do have two logs which I data logged when I was having the issue. Any help would be greatly appreciated. |
#2 | |
BAE
Drives: Asphalt FRS
i had the same MAP code, my sensor went bad after a track day so I ordered another 4 bar sensor and all is better now. The old 4 bar sensor was throwing codes for high voltage and the car didn't want to accelerate past 4k rpm in any gear. The code pretty much threw the car into limp mode. The bogging was terrible once i hit 4k rpm and it jerked/lurched the car over and over again. RPM spikes 500rpm everytime and CEL turns on. See if anyone near you can let you borrow a MAP sensor before you buy a new one. FYI i'm on Greddy T518z turbo w/ 11psi map tuned by Delicious. |
I'm running the sbd 500x kit with the omni 3 map sensor it comes with. Would it make sense to do in only in the rain? I changed my air filter thinking that it was the issue, and I have a pre-filter cover on it to minimize anything if water is hitting the filter.
| Another CEL code | whitefrs | Forced Induction | 20 | 11-27-2019 11:27 AM |
| DIY - Color Code of ID plate and code of part (SUBARU) - SB18-091 | Trap63 | DIY (Do-It-Yourself) Guides | 0 | 06-14-2018 04:52 AM |
| p0462 fuel level sensor code. anyone else ran into this code | georgiafrsguy | Engine, Exhaust, Transmission | 1 | 02-28-2017 08:28 PM |
| Lean Code and 02 Code diagnostics. | Kiske | Engine, Exhaust, Transmission | 12 | 04-28-2016 10:19 PM |
| CEL code | ChandlerSwyng | Issues | Warranty | Recalls / TSB | 2 | 04-08-2014 01:27 AM |
