Old 07-17-2018, 08:27 PM   #1
FRS_COLE
FRS_COLE's Avatar
Mystery rear end noise
I currently have a strange popping sound coming from the rear end. Happened not to long after installing my current set up which is BC extreme lows, PBM lca’s, and Racer X rear toe links. I’ve tried just about everything I can think of including torquing all the suspension bolts messed with under load, removed rear sway bar end links, and checked for play in hubs. I’m kinda out of ideas at this point and it’s driving me crazy. If anyone’s had this issue or know of a solution let me know. (Car in video isn’t mine but is making the same noise)
FRS_COLE is offline   Reply With Quote
Old 07-17-2018, 08:49 PM   #2
Joesurf79
Joesurf79's Avatar
Drives: 2016 White Pearl BRZ Premium
When you say all suspension bolts under load, you mean the strut shaft nuts up top too, right? It sounds like that or the strut top bearing dying maybe?
Joesurf79 is offline   Reply With Quote
Old 07-17-2018, 11:49 PM   #3
FRS_COLE
FRS_COLE's Avatar
I’ve done that actual strut bolts on the top. I haven’t done the one holding the top hat but I’m thinking it’s something to do drivetrain wise because when the car is cold the noise is hardly present and will rarely do it but after the car is fully warm after a drive it’s constantly doing it even when backing into a parking space pulling into a driveway etc..
Old 07-19-2018, 04:03 PM   #4
Imrac
Drives: 13 SWP BRZ Prem
Can you check your exhaust bolts. I see what looks to be condensation from your exhaust dripping between axle back and mid pipe flange. A loose connection there might explain why it changes before and after driving.
JDL UEL Headers, Nameless Res&Cat Over&Front, Invidia Q300 Catback, AVO Dry Panel Filter, Custom ECUTek Tune by DriftOffice
191WHP/151 ft-lb on 92
Imrac is offline   Reply With Quote
Old 03-18-2019, 08:43 AM   #5
TMF
TMF's Avatar
Drives: '14 FRS TT5
Bumping an old one..did you ever find the source of your noise? I have almost the exact same noise.
Follow my NASA TT5 build here: JHill Motorsports
TMF is offline   Reply With Quote
Old 12-01-2021, 05:08 PM   #6
MRBRZ1
MRBRZ1's Avatar
Drives: Subaru brz
did you guys find the issue?
MRBRZ1 is offline   Reply With Quote
Old 12-01-2021, 08:09 PM   #7
norcalpb
norcalpb's Avatar
It was probably OP putting spherical bearings in critical rear suspension areas, and driving on the street.
Noise coming from rear of car B-R-Z BRZ First-Gen (2012+) — General Topics 9 05-30-2017 06:04 AM
mystery body kit... (no longer a mystery) Alita Cosmetic Modification (Interior/Exterior/Lighting) 3 08-16-2015 06:10 PM
Noise in the Rear with ST Coilovers DemonRawr Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 05-01-2015 10:21 PM
Noise coming from the rear end... jm1681 Issues | Warranty | Recalls / TSB 17 03-13-2014 07:30 PM
rear brake noise norcal_brz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 08-19-2013 03:25 PM
