Old 07-17-2018, 04:38 PM   #1
gpvecchi
gpvecchi's Avatar
Does this exists?
I'm looking for a quiet catback, or better an axle back, in 60mm with just resonators and no mufflers.
Do you know if this exists?
gpvecchi is offline   Reply With Quote
Old 07-17-2018, 04:39 PM   #2
JeremyR
JeremyR's Avatar
Drives: 2015 BRZ Limited
anything without a muffler is going to make more noise than stock. you might be better off changing your exhaust tips if you want the look without the noise.
REALMS BRZ Build Thread
HKS|Parts Shop MAX|Battle Version|ADVAN|Beatrush
JeremyR is offline   Reply With Quote
Old 07-17-2018, 04:55 PM   #3
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
This? Namelss Single exit without muffler. FYI it's louder than stock. Even muffler ver was louder.
Old 07-17-2018, 04:57 PM   #4
humfrz
I would suggest you consider this axle back with 5" mufflers (just call the mufflers resonators ).
https://shop.namelessperformance.com...r-s-2013-2016/
humfrz
Old 07-17-2018, 05:24 PM   #5
Ernest72
Drives: 16 Silver BRZ, 04 Silver WRX wagon
I am with humfrz, mufflers muffle sound. Resonators resonate sound. Not sure you can get quiet without the muffle.
Ernest72 is offline   Reply With Quote
The Following 2 Users Say Thank You to Ernest72 For This Useful Post:
humfrz (07-17-2018), kch (07-18-2018)
Old 07-18-2018, 12:53 AM   #6
gpvecchi
gpvecchi's Avatar
Supersprint just use resonators, and they are very quiet. But the one for 86 is 63 mm.
Old 07-18-2018, 02:01 AM   #7
humfrz
From the outside, they look like little mufflers to me ..
humfrz
fika84 (07-18-2018)
Old 07-18-2018, 05:52 AM   #8
monkeybike
Drives: 86
Can I ask why 60mm is required and 63mm is unsuitable?!
monkeybike is offline   Reply With Quote
Old 07-18-2018, 07:10 AM   #9
gpvecchi
gpvecchi's Avatar
Nope, Supersprint just uses resonators in its exhausts, even the version with 1 resonator, it has Y drilled pipe inside. 63 mm moves torque toward high revs.
Old 07-18-2018, 08:02 AM   #10
15limited
15limited's Avatar
So to answer your question, No. An axleback or catback doesnt exist that's going to be "quiet" when you exclude the sections that make it quiet. And 3mm increase diameter in piping isnt going to make a dramatic leap and move all the TQs way high in the rev range, let's be real.
Sent from my SM-G950U using Tapatalk
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
The Following 6 Users Say Thank You to 15limited For This Useful Post:
chaoskaze (07-18-2018), Edibrac (07-18-2018), FRSBRZGT86FAN (07-20-2018), humfrz (07-18-2018), JohnJuan (07-20-2018), Spuds (07-18-2018)
Old 07-18-2018, 08:58 AM   #11
monkeybike
Drives: 86
You will be lucky to have any horsepower or torque difference with a catback so 3mm either way isn't going to shift your torque curve.
You said the supersprint has the resonators and the volume you want and basically the size you want. I'd just go with that. Don't get hung up on paper specs.
The Following 2 Users Say Thank You to monkeybike For This Useful Post:
humfrz (07-18-2018), JoeC (07-20-2018)
Old 07-18-2018, 09:35 AM   #12
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
I agree somewhat with your concern for pipe diameter.
I would go with keeping the piping the same as what is coming off your header/overpipe.
For example I had Gruppe-S UEL with overpipe that ended in 60mm.
Therefore I went with An Invidia FP an HKS catback 60mm. This keeps VELOCITY consistent all the way through.
Now I have just installed ACE 350 Headers/overpipe that end in 63mm(2.5").
So I just now ordered a Hooker HF cat/Helmholtz J-pipe Front pipe, And Agency catback exhaust all 63mm (2.5")
Will there be a huge change in HP/TQ I doubt it. But I like knowing the flow will be consistent all the way through without either bottlenecks (too small piping) or too slow velocity (too large piping).
SuperTom is offline   Reply With Quote
Old 07-18-2018, 09:38 AM   #13
fika84
fika84's Avatar
I'm also with @humfrz I can't find a version of their exhaust WITHOUT mufflers... https://www.supersprint.com/ww-en/to...-hp-12-16.aspx
Maybe the terminology or translation is different? Are you thinking of the Catalytic Converter?
fika84 is offline   Reply With Quote
The Following User Says Thank You to fika84 For This Useful Post:
humfrz (07-18-2018)
Old 07-18-2018, 12:03 PM   #14
humfrz
@gpvecchi what do you consider a "resonator", what do you consider a "muffler"?
humfrz
Racism and igorance still exists in America? Giccin Off-Topic Lounge [WARNING: NO POLITICS] 25 03-09-2011 02:37 PM
