Old 07-16-2018, 06:36 PM   #1
MyGT86Yas
Drives: 2017 WRB BRZ
2017 BRZ Stereo
I had a 86 before and the biggest difference I see between them is the sound system. The one comes with the Subaru is just terrible. The volume keeps changing on its own due to poor Bluetooth connection (I assume) and the sound is just awful. So I am thinking to replace the head unit and I contacted Crutchfield and was told that none of their stereos will work with the factory back up camera. Does anyone know a headunit that will fit in a 2017 brz (with a kit maybe?) and has Navi and is compatible with back up camera? I’m not familiar with all the terminology in Audio so I think I should just ask here.
MyGT86Yas is offline   Reply With Quote
Old 07-16-2018, 07:44 PM   #2
NCtoBRZ
Drives: 2017 Subaru BRZ PP WRB
Most any aftermarket head unit CAN work with the factory backup camera... but it isn’t a plug-n-play situation. I installed a Pioneer AVH2330-NEX in my 17 BRZ and I have all functions working (backup camera, BT, factory USB and Aux, etc.). If you aren’t comfortable with fairly advanced car stereo wiring, just take your car to a pro and let them know what you want and they’ll make it happen. Here is my thread detailing the fun that I had with this installation https://www.ft86club.com/forums/showthread.php?t=126171
NCtoBRZ is offline   Reply With Quote
Old 07-16-2018, 09:55 PM   #3
gt86yasss
Drives: White 86
I think I'm gonna get the same unit as yours, and I already called a shop and they gonna charge me around $150 for the harness and install labor, sounds reasonable to me. One more question, will I need a kit or a cover to fit the headunit?
gt86yasss is offline   Reply With Quote
Old 07-16-2018, 11:28 PM   #4
NCtoBRZ
Yes, you’ll need a dash kit to fill in the gap around the aftermarket head unit. For my installation I purchased:
-Maestro RR to retain steering wheel controls and add gauges
-Maestro T01 harness that was supposed to simplify installation... but I ended up modifying the harness to the point that I could have just used the hardwire harness included with the RR
-USB adapter to retain factory USB port
-antenna adapter for AM/FM radio
-dash kit
I don’t care about satellite radio, so I didn’t buy any adapters to retain it with the Pioneer radio. If you want to retain steering wheel controls but don’t care about adding gauges, there are cheaper options than the Maestro RR. The USB adapter is optional, only needed if you want to use the factory USB port. If the shop is quoting only $150 for installation parts and labor, they are definitely not using the Maestro setup and might be skipping some extras like the USB adapter and steering wheel controls.
CSCS Mid Summer DRIFT 2017 - Round 3 - SUN July 23 2017 @ TMP CAYUGA SB LAYOUT DTrouble CANADA 0 07-19-2017 08:42 PM
2017 CHRYSLER PACIFICA MINIVAN VS 2017 TOYOTA 86 WHO WINS IN A DRAG RACE??? Extreme Dimensions Off-Topic Lounge [WARNING: NO POLITICS] 6 06-08-2017 08:59 AM
Can 2017 owners review new stereo/touchscreen SubieSyncro Electronics | Audio | NAV | Infotainment 77 05-04-2017 10:51 PM
2013 BRZ Nav Stereo For 2016 BRZ Starlink Stereo brzsubarusti13 Audio/Visual, Electronics, Infotainment, NAV 11 02-27-2016 06:33 AM
Stock FRS stereo on Toyota 86 - Wiring problem position lights turn on/off the stereo dssence Electronics | Audio | NAV | Infotainment 0 01-27-2015 06:43 PM
