Old 07-14-2018, 09:17 AM   #1
Suzuyans
Something something
Drives: 2017 BRZ (Vortech), 1993 R32 GT-R
P0037 Fix
Hey guys! Did a few searches but, would rather have a second opinion. Also not sure if this is the right section.
So after getting my catless header, the person installing advised me not to install the secondary O2 sensors because the threads could damage my header so instead he put a plug that sealed it.
Initially I thought the OFT was going to disable it since I was told all it did was check if my catalyic converter is going alright and healthy. I thought the OFT was going to stop P0037 but, apparently it only fixes P0420.
I have the rear O2 sensor in my trunk. Is it possible to just ziptie or somehow tape it onto the side to make to keep it plugged it so I don't have to wipe P0037 every time I get into the car?
Suzuyans is offline   Reply With Quote
Old 07-14-2018, 10:02 AM   #2
churchx
churchx's Avatar
Drives: 2014 GT86
One running catless header should use ecu tune with it for several reasons. In proper ecu tune cat readiness tests should be disabled. No need to mess with weird hacks on sensor.
Old 07-14-2018, 10:12 AM   #3
Suzuyans
Something something
Yeah. I have an OFT but, that only disables P0420 though.
Is there a way to completely disable P0037 with Rom Raider?
Old 07-14-2018, 12:03 PM   #4
churchx
churchx's Avatar
Drives: 2014 GT86
P0037 - HO2S Heater Control Circuit Low Bank 1 Sensor 2
You could have googled. Most often it's damaged wiring/plug or fuse (EFI HTR #29). Most often fixing damaged wiring gets rid of the P0037. I have guess that it may have happened during your new header install.
The Following User Says Thank You to churchx For This Useful Post:
Ultramaroon (07-14-2018)
Old 07-14-2018, 02:48 PM   #5
Ultramaroon
not playing cards
Ultramaroon's Avatar
FA20 ENGINE CONTROL: SFI SYSTEM: DIAGNOSTIC TROUBLE CODE CHART; 2017 MY 86 [06/2016 - ]
Old 07-14-2018, 02:53 PM   #6
Suzuyans
Something something
Er I should elaborate. Basically the 2nd O2 sensor isn't plugged in. At all.
I know what it is I'm just curious if there's a way to route it.
I didn't install it because the threads came out horribly when the installer took it out of the stock header.
Instead there's just a cap.
Old 07-14-2018, 07:12 PM   #7
steve99
P0037 is rear 02 heater circuit low
This will be because you have removed rear 02 sensor
best reinstall it.
Car will run fine with it reinstalled
no need to remove it, however if you do remove rear 02 you need to disable a bunch of codes in tune plus disable the rear 02 fueling compensations.
best easiest solution is to reinstall rear 02 and plug it in to wiring harness
Im not sure what this guy is talking about "threads will damage header" if the sensor wont thread into header easily run a thread tap M18 by 1.5mm through header threads to clean it up.
Old 07-14-2018, 07:28 PM   #8
Suzuyans
Something something
Yeah he said it was useless since all the rear 02 sensor did was check to see if the cat was working which it wasn't because it's catless.
I have to plug it into the port though right?
Old 07-14-2018, 07:52 PM   #9
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
OP needs to do a little more reading- it's all on this forum. The car still needs the rear of sensor, reinstall it. Tune to get rid of the p0420. Don't listen to what some dude said and don't think so much.
The Following User Says Thank You to guybo For This Useful Post:
FRSBRZGT86FAN (08-14-2018)
Old 07-14-2018, 09:28 PM   #10
Suzuyans
Something something
Alright cool.
I hope it's doable without taking out the header again. I should be able to slip down under or can do it through the engine bay
Old 07-15-2018, 01:52 AM   #11
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Alright cool.
@guybo and steve99 is correct, you must have both o2 sensors installed regardless.
I don't know how you expect to mod a car without educating yourself about the mods you're installing. Also taking advice of someone who installed the header that obviously doesn't know this car well enough isn't smart...
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
guybo (07-21-2018)
Old 07-16-2018, 04:49 AM   #12
Kodename47
Kodename47's Avatar
Drives: UK GT86
FWIW I don't run a rear sensor, DTCs disabed, all golden.
.: Stealth 86 :.
Kodename 47 DJ:
Old 07-16-2018, 02:55 PM   #13
FRSBRZGT86FAN
I made that comment based on his post history
He doesn't seem to know much about the car and is only NA
Old 08-14-2018, 05:45 AM   #14
steve99
Yep that's about it disable codes related to rear 02 sensor and rear 02 heater circuit then disable rear 02 fueling corrections
http://www.ft86club.com/forums/showp...78&postcount=4
keen as (08-14-2018)
CEL - P0037 code pcuerpo Issues | Warranty | Recalls / TSB 1 07-19-2015 05:38 PM
