Old 07-13-2018, 12:12 PM   #1
elitegunslinger
elitegunslinger's Avatar
Drives: 2014 BRZ Limited
Hard Brake Line Part Numbers
Does anyone know what the driver side hard brake line part number is? I managed to shatter my flare wrench and round of the nut at the same time trying to install my stainless lines.
I contacted two dealerships and neither can properly identify the part number.
They provided me with 26517CA000 & 26517CA010 but these go from the master cylinder to the ABS module.
I'm looking for the hardline not the softline to confirm:
Thanks in advance.
elitegunslinger is offline   Reply With Quote
Old 07-13-2018, 03:05 PM   #2
stevesnj
stevesnj's Avatar
https://parts.subaru.com/Subaru_2014...nd-Brakes.html
My 2016 Build thread
Old 07-13-2018, 03:18 PM   #3
elitegunslinger
Originally Posted by stevesnj View Post
I've been digging through the diagrams, there is no definitive image that depicts this brake line; could you ID the part number?
Old 07-13-2018, 03:24 PM   #4
stevesnj
stevesnj's Avatar
Where exactly is the line at?
Old 07-13-2018, 03:28 PM   #5
FirstWinter
Drives: Car
Yeah, those are fairly easy to strip and you're usually SOL. Subaru might have it listed as the whole system together so it might not be possible to order that line by itself.
What I would do is just use a pair of vice grips and save the trouble of replacing. If you're only aiming to replace the stripped nut you can just cut off the brake line, replace nut (source from McMaster or something), and flare the end of the line. Nothing too complicated for a DIY. Could source something from a wrecked car. Check http://www.car-part.com/ or a local junkyard.
If you're not lazy like me I would get some new lines and bend it to shape. Looks like pic shows the front brake lines so it's nothing that bad. If it's the driver side front then it's super easy. [ame="https://www.youtube.com/watch?v=bqyoTWFZ5K4"]https://www.youtube.com/watch?v=bqyoTWFZ5K4[/ame]
FirstWinter is offline   Reply With Quote
The Following User Says Thank You to FirstWinter For This Useful Post:
elitegunslinger (07-13-2018)
Old 07-13-2018, 03:35 PM   #6
elitegunslinger
Front driver side hard brake line; the one that the soft line from the caliper connects to. It goes to the ABS unit and it maybe 6"-12" long.
What I would do is just use a pair of vice grips and save the trouble of replacing. If you're only aiming to replace the stripped nut you can just cut off the brake line, replace nut (source from McMaster or something), and flare the end of the line. Nothing too complicated for a DIY. Could source something from a wrecked car. Check http://www.car-part.com/ or a local junkyard. I'm pretty sure most totaled cars will still have an okay brake line.
I've been considering cutting and flaring the existing line if I can"t find the part number; realistically I could tighten it with the vice grips as is but it should be repaired imo.
Old 07-13-2018, 03:36 PM   #7
FirstWinter
Drives: Car
Did a bit of digging and I think this might be it? https://parts.subaru.com/p/Subaru_20...6517CA010.html
stevesnj (07-13-2018)
Old 07-13-2018, 03:37 PM   #8
stevesnj
stevesnj's Avatar
Could be this line...I don't have my car nearby to check though.
Old 07-13-2018, 04:14 PM   #9
elitegunslinger
It's tough to tell if that is the right part.
But here is an alternate view of 26517CA000:
I've contacted 3 dealerships and now Subaru of America; nobody can identify the part number with confidence.
I ordered both of these and we'll see if they're correct but I doubt it. I expect to receive both lines that run to the master cylinder and ABS.
The Following User Says Thank You to elitegunslinger For This Useful Post:
Old 07-13-2018, 04:40 PM   #10
elitegunslinger
Mystery solved boys; the part number you need is 26514CA010. Unfortunately it is every hard line in the front of the car.
Subaru apparently doesn't sell these individually for whatever reason and it costs between 108-150$ + shipping depending on where you buy it.
Old 07-14-2018, 12:14 AM   #11
Colin86
Drives: 86
I actually just had this same problem only I stripped both front flare nuts for the brake lines. I too panicked and wondered how to replace the whole thing until I found this magic tool: https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
It's a stupid price for a simple vice grip but it works. Clean the threads with brake clean and a brush if they're not already clean, heat the nut as hot as you can get it without melting the fender liner, spray penetrating lubricant on the threads after they're hot, and then clamp it with the above wrench and it'll come right off. Save you some headache having to swap the whole line.
Good luck!
Colin86 is offline   Reply With Quote
Old 07-15-2018, 01:29 AM   #12
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I had to replace my passenger side and order all the lines. I think I still have the driver side I can ship to you if you cover just that cost.
Old 07-16-2018, 09:51 AM   #13
elitegunslinger
That'd be great; I ended up vice gripping it down but I know I should replace it. I'll PM you.
Help! Brake line leakage after steel braided line install. ysu Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 02-09-2020 10:38 PM
Part Diagrams / Numbers for BRZ (like RealOEM for bmw), Part Vendors vlad128 BRZ First-Gen (2012+) — General Topics 7 06-29-2018 04:05 PM
WTB REAR DRIVER SIDE HARD BRAKE LINE Akuma-ZN6 Want-To-Buy Requests 0 12-11-2017 06:50 PM
Part numbers or part diagram? pacemkr Engine, Exhaust, Transmission 6 08-22-2016 01:44 PM
Subaru part numbers for stock brake rotors? blalor Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 06-28-2012 02:31 PM
