Old 07-11-2018, 03:19 PM   #1
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
SPL Rear Toe Links issues
I just had SPL real toe links installed to go along with their front and rear LCAs, rear traction bar and front bump steer links.
After about 40 minutes of track time one of the links moved to a new random and not so fun rear toe angle!
After inspection and contacting SPL it turns out that sometimes the titanium bolts on the clamps cannot be torqued enough so they recommended replacing them with steel. That was a shock given they make such a big deal of using titanium and now had us replace those with steel! WTF?!
I'm not even on slicks yet; on 245 AD08Rs. The whole point of switching from stock to SPL was to move to slicks!
I've had their rear LCA for several years with no issues.
Now I'm not sure I trust all those "precious" titanium clamp bolts on the other SPL parts, like the new front LCA...
Anyone else have issues with SPL parts?
Sleepless is offline   Reply With Quote
Old 07-11-2018, 04:43 PM   #2
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
That's real shitty of them not to stand behind their product and make it right by sending you the recommend piece to fix the issue. I bought a discontinued Raceseng pulley kit and noticed that they updated it at some point which was why it was discontinued and they sent me all new pulleys free of charge with free next day shipping. I would stop using SPL parts over this once I had the budget to get something else.
Trueweltall is offline   Reply With Quote
The Following User Says Thank You to Trueweltall For This Useful Post:
Turbo (07-12-2018)
Old 07-17-2018, 08:30 AM   #3
AxisPower
Drives: 23 GT4RS
This might seem like a stupid question but did these come with eccentric lockouts?
AxisPower is offline   Reply With Quote
Old 07-17-2018, 12:32 PM   #4
jamal
jamal's Avatar
Drives: Legacy GT
Yeah something like that wound be ideal, and pretty simple to do.
Cusco for example provides little washers with tabs that fit in the stock elongated holes in the crossmember so that the bolt can't slip, and Whiteline has toe lock kits to go with a lot of their adjustable links.
jamal is offline   Reply With Quote
Old 07-17-2018, 07:33 PM   #5
RJasonKlein
RJasonKlein's Avatar
Hmmm...I’m anxious to see additional replies, because I run them, too. Hey, Mike @CSG Mike, have you heard of this issue before and, if so, should I be worried?
Last edited by RJasonKlein; 08-08-2018 at 02:55 AM. Reason: Corrected a typographical error.
RJasonKlein is offline   Reply With Quote
Old 07-17-2018, 08:07 PM   #6
strat61caster
strat61caster's Avatar
If I understand SPL's design correctly an eccentric lockout won't do anything to prevent the slippage of the titanium clamp hypothesized to be OP's issue.
And they do come with square plates designed to prevent slippage of the eccentric end of the arm.
ineedyourdiddly
CSG Mike (07-17-2018)
Old 07-17-2018, 08:25 PM   #7
Stretching Titanium? The tensile strength of Ti is pretty darn high.
What exactly was the failure and which part? Is it possible it's installer error?
I've never heard of such a failure with SPL parts, and that doesn't sound like a very SPL answer to me; they stand behind their products 100% and I've seen them send full replacements when unusual failures happen.
RJasonKlein (07-17-2018), wparsons (07-17-2018)
Old 07-17-2018, 08:43 PM   #8
wparsons
wparsons's Avatar
For this to be an issue with the clamps, both of them on one arm would have to have come loose. If only one came loose the barrel wouldn't have been able to rotate and adjust the toe.
My gut says you're not running the eccentric lockout plate and that slipped? If it was actually both clamps on one arm, I'd bet a lot that they weren't tightened properly after the alignment.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
Old 07-17-2018, 09:00 PM   #9
AxisPower
Drives: 23 GT4RS
I didn't completely read the OPs post, didn't realize it was the little clamp thats loosening up. My only thought is that on the rear lower control arm they offer, there are essentially 2 clamps: the obvious small silver one, and the actual control arm itself where its split and can be tightened. This picture shows it pretty well:
The toe arm only has one clamp and the arm itself is solid with no splits on the ends that can be tightened. Compare that to another manufacturers toe arm like partsshopmax that has the same clamping style as spl's rear lowers:
Still think it might be an issue with the eccentric lockouts though, even if the clamps were loose, the toe shouldn't be able to change easily because the barrel needs to be turned somehow to lengthen/shorten the arms.
The Following User Says Thank You to AxisPower For This Useful Post:
Old 07-17-2018, 09:00 PM   #10
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
It was the clamp(s) and am running the lockout version.
SPL has seen this happen a few times and didn't really have an explanation. They said to switch from the Ti to steel bolts which we did. I'll be testing it with 245 Z214s on thursday.
Old 07-17-2018, 09:05 PM   #11
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
There is no hypothesizing, it was the clamp held by the Ti bolts. SPL had us replace them with steel bolts and torque to 250 instead of 150.
The Following 3 Users Say Thank You to Sleepless For This Useful Post:
CSG Mike (07-17-2018), RJasonKlein (07-18-2018), strat61caster (07-17-2018)
Old 07-17-2018, 09:10 PM   #12
AxisPower
Drives: 23 GT4RS
Was the bolt for the clamp still tight and the clamp itself slipping, or had everything seemed to loosen up?
Old 07-17-2018, 09:25 PM   #13
strat61caster
I don't think you're looking at the right part:
ineedyourdiddly
Old 07-17-2018, 10:37 PM   #14
AxisPower
Drives: 23 GT4RS
I was just trying to make the point that the rear lower control arm, which I posted a picture of, doesn't have issues with loosening up like the toe arms because it essentially has two clamps vs the toe arm which only has one.
WTB- 1 or 2 OEM rear end links solort Want-To-Buy Requests 3 08-18-2017 05:32 AM
FS: Brand New Racer X Billet Rear LCAs, Rear Toe Links, and Front Tie Rod Ends EGOBRZ Brakes, Suspension, Chassis 4 07-12-2017 12:12 PM
Adjustable End Links (Rear) digital_assassin Brakes, Suspension, Chassis 2 09-26-2015 04:43 PM
FS: Rear Toe Links, OEM Fog Lights FRS2000 Brakes, Suspension, Chassis 3 11-14-2014 08:04 AM
Rear Toe Links? Supermassive Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 11-05-2012 05:29 PM
