Old 07-09-2018, 03:16 PM   #1
szjalo
Drives: 2014 Scion FR-S
quick question: can 4 stock tires fit in my frs?
Due to some reasons I have to buy tires online and directly ship to me and I need to drive the tires to local tire shop(which does not accept online shipping). Before I pull the trigger just want to know if I try my best would it be possible to fit all four stock sized tires in my frs? has anyone successfully done that?
The car is stock 2014 frs monogram. tires are also the factory size 215/45R17.
Thanks a bunch!
szjalo is offline   Reply With Quote
Old 07-09-2018, 03:20 PM   #2
KDad2
KDad2's Avatar
Drives: 2013 Raven
Yes you can! And plus some...
KDad2 is offline   Reply With Quote
The Following User Says Thank You to KDad2 For This Useful Post:
Leonardo (07-09-2018)
Old 07-09-2018, 03:22 PM   #3
Joon525
Joon525's Avatar
Drives: 2016 BRZ
Yes.
But use some common sense, if you're going to try to carry a bunch of other stuff (a lot of other stuff) you're going to have a hard time getting everything in there.
Also.....if you just google this very question you'll see pictures and even video on how to do it.
Joon525 is offline   Reply With Quote
Old 07-09-2018, 03:28 PM   #4
ST185RC
Drives: White Out FR-S
The car has been marketed to fit a full set of track day wheels in the trunk with the seats folded down PLUS a floor jack.
Keep in mind that they made this claim with an empty stock trunk. if you have party balloons and an elephant in the back, 4 stock wheels probably won't fit
ST185RC is offline   Reply With Quote
Old 07-09-2018, 03:28 PM   #5
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
Quick answer: yes.
Longer answer: They can't sit all flat side by side, but they'll all fit. Until recently I was packing my set of summer or winter wheels (with tires mounted) into the car to have the dealer swap them over for me. They'd repack the car and I'd head home. Totally doable. Just drop the back seat, scoot the passenger seat and seatback up a little, put two of them back there more or less side by side, insert one through the trunk and lift it to rest on top of the first two at an angle, and then insert your last one into the trunk, it'll probably be off set to one side wherever you have the most room. And off you go.
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
The Following 4 Users Say Thank You to Overdrive For This Useful Post:
jordan7831 (07-10-2018), strat61caster (07-09-2018), ToySub1946 (07-09-2018), wolffbite (07-11-2018)
Old 07-09-2018, 03:32 PM   #6
humfrz
Yes, if the trunk monkey moves over ..
humfrz
The Following 3 Users Say Thank You to humfrz For This Useful Post:
Impureclient (07-09-2018), Overdrive (07-09-2018), why? (07-11-2018)
Old 07-09-2018, 04:03 PM   #7
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
You don't even need to use the trunk, just fold the rear seats down and stack them 2x2.
Another solution is ratcheting straps, all 4 wheels standing, and route the straps through the tires and use the baby seat anchors on the rear shelf to tie down.
Jyn is offline   Reply With Quote
Old 07-09-2018, 04:36 PM   #8
TorontoNat
Drives: 2013 Scion FR-S Asphalt [Gray]
oops, Someone missed the marketing. Well done. Now we know you got it to drive it and ask questions about little details after.. I like it.
"Enjoying Performance because of it's nature not because of it's quantity''
TorontoNat is offline   Reply With Quote
Old 07-09-2018, 04:54 PM   #9
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Normally yes, but since yours is a Monogram, then no.
Originally Posted by humfrz
I'm old and lazy
Old 07-10-2018, 02:06 AM   #10
Smalaihollo
Smalaihollo's Avatar
Drives: 2015 Ultramarine frs
Should fit no problem!
IG: @GG.FRS
Smalaihollo is offline   Reply With Quote
Old 07-10-2018, 02:25 AM   #11
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Thanks a bunch!
As others said of course! Drop the Rear seats and you'll have more than ample amount of room. The rear area was supposedly designed to fit a set easily.
Old 07-10-2018, 05:30 AM   #12
FLIPDADY
FLIPDADY's Avatar
Drives: 2015 Subaru BRZ Sport Tech
I fit 4 x 235/45R17 winters mounted on 17x8 wheels no problem. Rear seats down front passenger seat reclined back.
Sent from my SM-G930W8 using Tapatalk
FLIPDADY is offline   Reply With Quote
Old 07-10-2018, 07:58 AM   #13
Overdrive
Sittin' Sideways
Overdrive's Avatar
Because....?
-O/D
2016 FR-S, Hot Lava
Old 07-10-2018, 08:09 AM   #14
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
humfrz
Best commercials.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
venturaII is offline   Reply With Quote
The Following User Says Thank You to venturaII For This Useful Post:
humfrz (07-10-2018)
Quick question for OFT Enrique_13 Engine, Exhaust, Transmission 4 06-29-2018 01:29 PM
BRZ Stock Tires and region question ~el~jefe~ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 01-02-2017 11:39 PM
Question: Will 225/45 or 225/50 winters tires fit the stock wheels?? wbradley Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 12-30-2013 03:13 PM
Stock tires, new rims. Question? CodyFRS Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 05-30-2013 10:34 AM
Quick Question geb2391 BRZ First-Gen (2012+) — General Topics 2 04-07-2013 11:41 PM
