Old 07-08-2018, 06:23 PM   #1
Heat Sinker
Drives: 2016 FR-S
Adding/Switching to BOV for Supercharger
I searched around the forums and did not come across any thing that really answered my question.
I have a JRSC on currently and I want to add a Greddy RS BOV to the system. I have a HKS SSQV (2 or 3) available right now till I can buy the Greddy.
My question is what would be the process add a BOV that vents to the atmosphere?
I assume I would need to find a proper spring (for HKS) and the Greddy is a turn dial??
What are the implications of changing the system? I have an understanding that I am changing the air flow in the system and it can interfere with the performance as I am taking air away from the system that the MAF has already calculated into the equation. Is that correct? Would I need to have my car's tune adjusted or can I just install it and be on my way?
Please feel free to add anything else I am missing.
Thank you in advance. This is more a cosmetic thing than a performance modification.
Heat Sinker is offline   Reply With Quote
Old 07-08-2018, 07:12 PM   #2
EchoHotel
Drives: 2013 FR-S Hot Lava
I have a tail Q50 mm with supercharger spring and it’s great. It’s a 2psi spring rate.
Hope that helps.
Erik
EchoHotel is offline   Reply With Quote
Old 07-08-2018, 08:18 PM   #3
mrg666
pessimistic skeptic
mrg666's Avatar
Your answer is in JRSC owner's thread. You didn't search enough.
Old 07-08-2018, 09:11 PM   #4
Heat Sinker
Drives: 2016 FR-S
Thanks for the tip, I searched through all 17+ pages my search/s came up with and didn't not find what I was looking for. I saw 3 of your posts which one basically states to not do it it can damage your SC.
The other two I saw was your posts that were talking about updating the diverter valve to a metal one vs the OEM plastic one.
Old 07-08-2018, 09:45 PM   #5
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Pg 42. 308, 309.... look like good places to start in the JRSC owners thread. I just did a 5 second Google search and quick perusal.
Old 07-08-2018, 09:49 PM   #6
Heat Sinker
Drives: 2016 FR-S
I saw those.
The conversation was asking about putting on a BOV, the asked why would someone want to. Followed up with it’s a BPV essentially the same thing.
The next 5 pages I went through did not continue this conversation.
Thank you though.
Old 07-08-2018, 09:58 PM   #7
Summerwolf
Panda Trueno
Summerwolf's Avatar
There are pictures and quite a bit of conversation concerning adding a Bov, direct replacement part numbers and also some interesting comments from @CSG Mike
Old 07-08-2018, 10:00 PM   #8
Heat Sinker
Drives: 2016 FR-S
Apologies I read only page 42.... for some reason I thought I was looking for post 308-309 instead of page 308-309. Reading it now
Thank you
Old 07-09-2018, 05:15 AM   #9
You can just weld it onto your charge pipes.
Probably before your air straightener in your case.
You WILL need a re-tune.
Switching to 4x100 why? Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 11-23-2017 09:16 PM
Mods before adding turbo/supercharger pattyb86 Forced Induction 15 06-29-2015 06:47 PM
So I'm thinking from switching from a supercharger to a turbo. cjsporl1996 Forced Induction 82 05-12-2014 06:10 PM
Switching to E85 and back bfrank1972 Engine, Exhaust, Transmission 8 09-10-2013 10:16 PM
Switching oils ArKiTeCkT Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 10 04-24-2013 01:24 PM
