Old 07-06-2018, 11:22 AM   #1
Cojonudo
I'm New
Cojonudo's Avatar
Drives: 2016 Limited Subaru BRZ White Pearl
OFT Flex Fuel Kit or Delicious Tuning?
I was wondering what the differences are between both kits and which would be better? I’m currently running Stage 2 UEL Headers on 93 Octane tuned with my OFT. Any input or advice would be greatly appreciated. Thank you!
"You do you"
Cojonudo is offline   Reply With Quote
Old 07-06-2018, 12:27 PM   #2
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
Firstly, there is no "Flex fuel kit" for OFT. You just flash an e85 tune (along with steps for getting the 91/93 out of the gas tank) and go.
BigTuna is offline   Reply With Quote
Old 07-06-2018, 01:07 PM   #3
zero_limits
Drives: Subaru BRZ 2017 PP
I thought you needed a tune, along with a flex fuel kit?
Isn't this the flex fuel kit for OFT?
(correct me if I'm wrong, I don't have OFT but eventually want to go the e85 route)
http://www.openflashtablet.com/shop/...flex-fuel-kit/
zero_limits is offline   Reply With Quote
Old 07-06-2018, 01:12 PM   #4
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
There is a flex fuel kit but you don't need it to run e85. You can just do what BigTuna said or take it a step further with the e85 kit you mentioned.
To answer your main question, Delicious tune.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
Old 07-06-2018, 01:31 PM   #5
Cojonudo
I'm New
Cojonudo's Avatar
They do have a Flex Fuel Kit...
"You do you"
Old 07-06-2018, 02:56 PM   #6
SkyeHack
SkyeHack's Avatar
Drives: 2018 BRZ tS
SkyeHack is offline   Reply With Quote
Old 07-06-2018, 04:10 PM   #7
BigTuna
BigTuna's Avatar
Originally Posted by SkyeHack View Post
lol guys, I realize I was wrong. What I meant was that you don't need one to run e85 with OFT.
To the OP, I ran e85 with the OFT (without the flex fuel kit) and I definitely noticed the hp bump while driving. It's a lot cheaper than a flex fuel kit too, since you already have the OFT, it's free to swap over.
Old 07-06-2018, 07:28 PM   #8
Cojonudo
I'm New
Cojonudo's Avatar
I understand but e85 isn’t readily available in my area so I rather have the flex fuel kit than having to flash back each time and running my tank to almost empty. Thanks for your input though I see where you’re coming from. I just would like to know which is better or if it doesn’t really matter.
"You do you"
The Following User Says Thank You to Cojonudo For This Useful Post:
Scala (09-10-2018)
Old 09-10-2018, 10:31 AM   #9
Scala
Drives: 2018 BRZ tS
Bump.
I'm in the same boat as the OP. Is Delicious the only way to go for a quick switch from 93 to E85?
Scala is offline   Reply With Quote
Old 09-10-2018, 10:46 AM   #10
stlgrym3
Drives: 2017 Subaru BRZ Limited
Delicious tuning all the way. I’m currently doing tune revisions for my delicious flex fuel kit with Zach. I’m already on my 10th revisions, OFT would be like getting the original tune and live with it the rest of the way, no revisions no logging. It’s easier and cheaper but not the best solution imo.
stlgrym3 is offline   Reply With Quote
The Following User Says Thank You to stlgrym3 For This Useful Post:
Scala (09-10-2018)
Old 09-10-2018, 10:52 AM   #11
Scala
Drives: 2018 BRZ tS
Thank you. Does the Delicious Tuning kit require a EcuTech tune in order to work properly? I was hoping to avoid the high cost of the ET by going with the Open Flash.
Old 09-10-2018, 11:19 AM   #12
stlgrym3
Yes it does require ecutek cable and license
Scala (09-10-2018)
Old 09-10-2018, 12:23 PM   #13
Scala
Drives: 2018 BRZ tS
Thank you!
Old 09-11-2018, 02:52 PM   #14
slowest86
Drives: slow frs
Ive had the OFT flex fuel kit for about two years now. Ive never had any problems and every time I send shiv a email I get a response back quick.
slowest86 is offline   Reply With Quote
The Following User Says Thank You to slowest86 For This Useful Post:
vintagemxer (09-12-2018)
Delicious Tuning Flex Fuel Kit Mark 1+ Fuel Pressure Safety System DeliciousTuning Software Tuning 20 06-09-2016 06:21 AM
Delicious tuning flex fuel kit DIM HAWAIICALIVEGAZ Engine, Exhaust, Transmission 0 05-16-2016 02:49 AM
Delicious Tuning Flex fuel kit themooseisloose Engine, Exhaust, Bolt-Ons 26 05-01-2015 11:46 AM
Delicious tuning flex fuel brz23 Great Lakes 2 03-06-2015 07:53 PM
Delicious tuning flex fuel brz23 Software Tuning 4 03-05-2015 12:28 PM
