Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > NY / NJ / CT / PA
NY / NJ / CT / PA NY, NJ, CT, PA
Old 06-29-2018, 07:22 AM   #1
Ernest72
Drives: 16 Silver BRZ, 04 Silver WRX wagon
Cosworth power blocks
Anyone have them in the tristate area with a AT?
Worth it if I am already at stage 2 catless UEL header? I have no plans of doing FI for this daily driver.
Any thoughts? And yes I read the thread on here which was mostly positive.
Ernest72 is offline   Reply With Quote
Old 06-29-2018, 09:30 AM   #2
bfrank1972
Drives: 2013 FR-S Argento
You mean Crawford? I didn't know Cosworth made power blocks
bfrank1972 is offline   Reply With Quote
Old 06-29-2018, 09:40 AM   #3
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
I suggest using Google to search this site.
There are numerous threads you can read here discussing this product. Participate in one of them as opposed to restarting a conversation that's already been had
Give this Google search a go: "site: www.ft86club.com crawford power blocks"
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
Old 06-29-2018, 10:17 AM   #4
Ernest72
Also wanted to know if someone nearby has them, hence my first question and why it’s here in tristate.
And yes Crawford, my bad.
Old 06-29-2018, 10:49 AM   #5
bfrank1972
Ok - I have a set of Crawford blocks sitting around waiting for install sometime this summer. Might end up being this fall though as I'm going on a long mid July to mid Aug - but if you end up waiting a bit I'll have mine installed eventually. Also have a custom tune with large diameter 4-1 EL headers, so I'll probably end up doing some tweaking with that to optimize the blocks. I also run gas as E85 is too much of a pain to get here in CT (I live in Westport). Will let you know when I get around to putting them on.
Old 06-29-2018, 11:06 AM   #6
Soloside
-Phil's BIGGEST FAN BOI
Drives: 2014 Greddy Turbo BRZ
"I have no plans of doing FI for this daily driver. "
This phrase always triggers me.
If you're looking to get a bit more punch in the lower rpm, since the blocks shift the power band, you should look into doing a 4.88 gearing swap. I recently did it and it peps the car up a lot.
2014 Subaru BRZ
Don't follow your dreams, follow my instagram www.instagram.com/soloside
Soloside is offline   Reply With Quote
Old 06-29-2018, 12:59 PM   #7
Ernest72
Thanks for the responses. I will look into the gearing. Although that is likely more expensive but it sounds like it might be worth it.
Old 06-29-2018, 02:13 PM   #8
bfrank1972
Do both + good header & custom tune. Probably biggest bang/buck for this car outside of FI.
Old 06-30-2018, 09:53 AM   #9
Ernest72
Ok. So after some research on the 4.88 drive I decided against it. Highway gas mileage takes a hit and I have a 78 mile round trip commute and I like my 33mpg. This car really is a daily driver.
Anyone else out there with an opinion on the Crawford blocks?
Old 06-30-2018, 10:32 AM   #10
Soloside
your MPG is going to suffer from the power blocks as well. Any edit to how the car came out of the factory will lower your MPG.
2014 Subaru BRZ
Old 06-30-2018, 11:25 AM   #11
Lantanafrs2
Drives: 2013 frs red
I kinda like mine. Fuel mileage is tune related. On e85 I rarely need to run past 5k rpms.
Old 06-30-2018, 03:01 PM   #12
PNW-BRZ
PNW-BRZ's Avatar
Drives: 2015 Limited
It's what I did on my 6MT. Have GruppeS UEL's, Tune and went with 4.56.
The gearing shifts the powerband close to where it should be. I'm happy I did the gearing, if I had to do it again I would probably look at the 4.88. If you want the best bang for the buck (i.e. tight budget), check out the scrap yards for a 2017+ manual, they have the 4.30 gearing.
PNW-BRZ is offline   Reply With Quote
Old 07-01-2018, 08:24 AM   #13
gravitylover
I got a stage 1 tune and my mpg jumped a couple. I can pretty easily cruise at 33-35 now and the car's happy spot went from ~72 to 75. I'm wearing down what's left of my winter tires so that's with sticky rubber on warm pavement, I am really curious what it can do with more appropriate shoes but my summer tires are completely worn out so just gonna run these until they're dead too.
Old 08-23-2018, 03:16 AM   #14
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
That hilariously untrue, that's dictated by how your tune handles fueling tables, AFR and load tables. Driving comparatively, I can get the same MPG with the Stage 2 UEL 93 octane tune as with the stock tune with stock UEL. I've made considerable tune edits to my 93 tunes to achieve this without loss of power, of course when I'm flooring it all the time the 93 tune will do worse than flooring it with the stock uels and tune, obviously the trade off for more power.
e85 and Crawford power blocks Lantana frs Engine, Exhaust, Transmission 10 07-21-2018 11:34 AM
Crawford power blocks Lantana frs Software Tuning 2 10-11-2016 09:54 PM
Crawford Power Blocks absolute Engine, Exhaust, Bolt-Ons 3 05-17-2015 11:21 AM
Crawford power blocks fs Triumphrider Engine, Exhaust, Bolt-Ons 2 04-06-2015 11:17 AM
Crawford Power Blocks like new oTaGGeDo Engine, Exhaust, Bolt-Ons 0 07-27-2014 09:22 AM
