Drives: 2013 Subaru BRZ
Faulty Cat causing engine problem?
Hey guys I’ve had a faulty catalytic converter for about two months now, it’s the front one by the header, as described by my mechanic. After this finding, sometimes when I drive ( usually when I’m pushing my engine a bit more into 3000 rpms and higher, the rpms indicator starts rapidly going down and up. Almost like my car is in limp mode. To fix this issue, i usually pull over to the side and rev my car a couple times into at least 6000rpms and drive again. I’m not sure why this happens but it can be stressful as I have to drive slowly in order to avoid this problem happening to my rpms. I am about to purchase a new catted header so hopefully this helps. Has this happened to anyone before?
#2 | |
Proud of BOXER
Drives: Subaru Boxer
How did your mechanic make the determination that the primary cat was "faulty"?
Sorry I forgot to specify a couple things. The first code that appeared was P0420 CATALYST SYSTEM EFFICENCY BELOW THRESHOLD (BANL 1). I have been getting a horrible 18mpg. However after a few weeks the problem above occurred and i got an ABS light, a traction control light, and a blinking check engine light. My next check I got these codes
C1201 Engine Control System Fault C1294 U0073 Control Module Communication Bus Off U0126 Lost Communication With Steering Angle Sensor Monitor |
#4 | |
U0073 and U0126 appears sometimes when someone plugs in something odd or faulty into the OBDII port. How many miles do you have? It's odd for a CAT to go bad 5 years in, did you have issues with burning oil or anything else like that? I would make sure you take it to a dealer that knows this car a bit better. Did he Check the o2 sensors specifically?
Plugged cat????, cheaper to gut that bitch and buy a tune!
#6 | |
I tried recording it happening , see what y’all think |
#10 |
Drives: 2017 BRZ Limited, Perf Package
Flashin CEL indicates a misfire, which poor exhaust flow can cause. Clogged cat doesn't sound out of the question.
If this happens at lower speeds as well. You could remove the upstream 02 and see if this problem goes away (creating a new path around the restriction). |
| Which problem parts should be replaced while engine is out of the car? | Asus | Engine, Exhaust, Transmission | 17 | 08-01-2017 10:02 PM |
| Replaced transmission fluid, now it's causing problem | frslee | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 37 | 11-02-2016 05:35 PM |
| Caster off, is this causing the problem? | dem00n | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 18 | 07-18-2015 11:31 AM |
| CAI causing check engine light | ZombieBadger | Issues | Warranty | Recalls / TSB | 13 | 01-18-2015 07:20 PM |
