Drives: 2017 Toyota 86
I want more grip than the stock tires with 18x8.5 wheels.
Hi everyone, I ordered a set of Work Emotion Kiwami wheels with a +38 offset. I decided on a 225/40/r18 square setup and basically want to know:
1. 225/40/18 is a bit stretched on an 18x8.5 wheel. Will it be super easy to curb and scratch up my rims? I hope not. 2. I live in Florida, do I really need all season tires? It seems that the summer tires are grippier and it isn't always raining here. Surely most summer tires in 225/40 have better grip than the stock 215/45 Primacy tires in dry+wet conditions. 3. Would basically anything on tire rack that costs around 150+ per tire have better grip than the primacy tires? I see so many tires at around $600 for a set and that seems a bit cheap to me. I was thinking about these Pirelli P Zero tires: https://www.tirerack.com/tires/tires...num=24YR8PZ4XL Or Continental Extreme Contact all seasons: https://www.tirerack.com/tires/tires...m=24YR8DWS06XL Thank you all in advance for your help. |
Wes
From personal experience I can say:
1. Yes 2. No 3. Yes. The stock tires can be pretty terrifying. It's like they have minds of their own. Got rid of mine after a week.
Instagram: @gt86ws
| The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post: | HachiRokuX (06-28-2018) |
Drives: 2015 BRZ
1) Yes
2) No 3) Look into Firestone Firehawk Indy 500 tires. Great tires at a low cost i recently bought these tires and im happy with them as are other members who have bought them. |
| The Following User Says Thank You to Vital For This Useful Post: | HachiRokuX (06-28-2018) |
Thanks guys, I read that I should be fine up to 235/40/18 on TRD springs so I might go that route with the firestone tires.
Is 235/40/18 too much tire for stock power, though? Heavy wheels and tires will already make it feel a bit more sluggish and 235 seems a bit wide if I want okayish acceleration. I’ve never tried it so idk. Sent from my iPhone using Tapatalk |
Country Boy 4 Life
https://tiresize.com/calculator/
Use a tire size comparison calculator. It will show you the difference in sizes. A 235/40 is fairly tall at 25.4", which is a 3.3% diameter difference. +/- 3.0% is generally the rule, though 235/40 will work ok. Personally, I'd get a sticky 225/40/18. The tire selection in this size is HUGE, prices are lower because it is a common size, and it is within the prescribed diameter range. 225/40 compared to the 235/40 If you get the Fire hawk, the 235/40 is only .1 inches wider, but costs $27 more each, weighs 1lbs more, and will make your speedo less accurate. Tire specs pulled from Tirerack.com
I LIKE TIRES! |
| The Following 2 Users Say Thank You to Leonardo For This Useful Post: | HachiRokuX (06-28-2018), Vital (06-28-2018) |
Drives: 2015 BRZ
I agree with Leonardo. I know the stretch look is subjective, but I have seen the tire and wheel spec in person and to me it was a slight stretch. I didn't think it was too bad. If you can help it stick with the 225/40/18.
| The Following 2 Users Say Thank You to Vital For This Useful Post: | HachiRokuX (06-28-2018), Leonardo (06-28-2018) |
| FS (GA) 15 BRZ Stock Wheels + Tires + TPMS + stock lugs & locks (tires 10k miles) | GTHachiRoku | Wheels and Tires | 15 | 07-30-2016 11:51 AM |
| WTB: 18x8-9 Wheels Wrapped in Tires | Mufasa | Want-To-Buy Requests | 2 | 03-17-2016 07:43 PM |
| FS ATL: Winter Goodyear Ultra Grip Ice WRT tires & steel wheels $400! | mweidner311 | Wheels and Tires | 7 | 02-21-2016 05:20 PM |
| Downsizing Wheels and Tires -- I Want Less Grip and More Sidewall! | Rosso_Corsa | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 35 | 02-10-2014 09:17 AM |
| do stock tires lose a lot of grip in low temps? | autobrz | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 28 | 10-28-2013 11:31 PM |
