Old 06-26-2018, 06:01 PM   #1
bmxr
bmxr's Avatar
Drives: 2017 BRZ PP WR Blue
Lateral HVAC vents
I noticed that my lateral HVAC vents seem to open and close with virtually no resistance, resulting in them actually falling shut over bumps or blowing shut when the fan is on high. Have any of you had this issue and fixed it? It's pretty annoying because I cannot direct air where I want it - they are basically either open all the way or shut...
bmxr is offline   Reply With Quote
Old 06-26-2018, 06:15 PM   #2
rvoll
Drives: 2018 BRZ Limited, 2017 Sportage
This is a warranty issue with a 2017. Have your dealer replace the vent.
rvoll is offline   Reply With Quote
Old 06-27-2018, 11:37 AM   #3
bmxr
bmxr's Avatar
I get that it should be under warranty, but is it a common issue? TSB? Is there a fix that others use absent warranty?
Old 06-27-2018, 11:48 AM   #4
rvoll
Haven't heard of this problem before. Do you fiddle with it a lot? Do you attach a phone mount to it? In any case, get your dealer to fix it...
Old 06-27-2018, 12:31 PM   #5
humfrz
Bubba says just to jam a match book in it..
Bubba - out
Old 06-27-2018, 02:07 PM   #6
spike021
spike021's Avatar
Silly question but side circular vents or center vents?
Lateral usually means toward the sides but this sounds more like the center vents.
Instagram: @spike.grc
spike021 is offline   Reply With Quote
Old 06-28-2018, 08:34 AM   #7
bmxr
bmxr's Avatar
No.
No.
Ok...
Yes, lateral means the sides. The center vents kind of suck, too, but they don't close completely simply because the fan is blowing.
Maybe I need to find a matchbook? lol
TRADE: Indianapolis area, BRZ DGM fender vents for FR-S asphalt vents Evil Minion Exterior Parts (Aero, Lighting, Etc.) 1 05-10-2015 06:52 PM
Vis Racing CF fender vents & Oem vents albertnamo Exterior Parts (Aero, Lighting, Etc.) 11 08-15-2014 10:00 AM
DIY: Cusco Rear Lateral Links RallySport Direct DIY (Do-It-Yourself) Guides 0 10-08-2013 11:40 AM
Want to trade my BRZ fender vents for you FRS fender vents, or buy FRS vents outright ill roller Exterior Parts (Aero, Lighting, Etc.) 6 09-22-2013 10:49 PM
WTB BRZ galaxy blue fender vents or trade w my FRS UM blue side vents BlueLeader Exterior Parts (Aero, Lighting, Etc.) 0 03-18-2013 02:55 PM
