Old 07-26-2012, 12:54 PM   #1
jedibow
post whore extraordinaire
Drives: 2013 Asphalt Grey FR-S 2003 Evo 8
SQC Tuning Turbo kit
I wanted to start this thread as Eric and I will be designing a turbo kit for the FR-S/BRZ.
I will share as many details as I can, and other design suggestions along the way. I would also like to note that both Eric and I work full time jobs so we most likely will not post during the day.
Turbo & Hotside
So far we have decided to utilize a mass produced journal bearing turbo, most likely a t3 derivative, or possible a precision unit. We are still debating on whether to forward mount and use a draw through system, or rear mount and have it be a blow through system (there are advantages to both). We will be making a turbo manifold either way, flanged for the turbo that we select. This will also feature an external wastegate, as we prefer the boost control on an external gate versus an internal gate. The system will utilize the factory exhaust starting in the midpipe. This completes the Hot side design thus far.
Cold side
Traditional front mount intercooler, unit to be determined. Aluminum piping most likely in a wrinkle finish. Blow off valve(if blow through) bypass vale(if draw through). T-bolt clamps, and silicon couplers.
Plumbing
We will be tapping the engine(specific location) for a gravity feed (read no scavage pump) and feed off the oil sending unit. Water cooling will be determine once turbo selected.
Tuning
We are going to be using EcuTek to reflash the stock ECU, along with larger port injectors to control AFR, and ignition mapping.
Design goals: Make 260 to 300 dependable whp, using between 6-10 psi, keep the cost of the turbo kit below $5,000. Make it turn key so that you do not have anything else to purchase (read:tuning, hoses, fittings, fuel pump...)
We appreciate any questions, or design suggestions...
George and Eric
Big thanks to John at Vtuned (Visconti)
P.S. we will post what pictures we can, and update THIS post as the design direction is decided.
Here is a link to past projects...
http://www.sq-creations.com/sqcturbo.html
P.P.S. HaHa
To avoid misunderstanding... This will be the base kit, we will offer options to those wishing to have a different setup (wastegate options, turbo options, possibly a stand alone option also).
Originally Posted by ImAwesome
Great info in here. arghx7 what do you do?
He's obviously a very knowledgable landscaper.
jedibow is offline
Old 07-26-2012, 12:55 PM   #2
jedibow
Saved for information update and images....
First planning session completed, disassembled the car, picked the turbo location, oil feed, and return, intercooler piping routing, and intercooler location. Went very well!
Now the fun begins as we will be fabricating the parts HaHa!
jedibow is offline
Old 07-26-2012, 12:55 PM   #3
jedibow
Saved for dyno graphs and datalogs
jedibow is offline
Old 07-26-2012, 12:57 PM   #4
SkullWorks
Drives: SSM LT MT BRZ
I guess I'll be the only guy developing a turbo kit with Standalone?
Glad to see it's gonna be a party! The more the merrier.
SkullWorks is offline
Old 07-26-2012, 12:59 PM   #5
jedibow
Due to the cost point we decided to go a different direction, however Eric is very capable with the AEM, and we could always offer it as an option...
G
jedibow is offline
Old 07-26-2012, 05:30 PM   #6
subatoy
subatoy's Avatar
Drives: subatoy
sounds exciting!
I'm guessing you'll need around 10 psi just to hit 250whp which kind of scares me in the reliability department.
can't wait to see the progress.
subatoy is offline
Old 07-26-2012, 05:34 PM   #7
FIREISFUN135
FIREISFUN135's Avatar
Drives: 2013 BRZ DGM
good luck on the 5 grand mark
FIREISFUN135 is offline
Old 07-26-2012, 05:35 PM   #8
jedibow
Originally Posted by subatoy View Post
sounds exciting!
We are calculating flow, not just pressure. The more the compressor flows the less pressure required to attain a given horsepower.
We are designing the kit around a 4000 to 4500 RPM useable powerband.
jedibow is offline
Old 07-26-2012, 05:36 PM   #9
jedibow
Under 5k HaHa Thanks!
jedibow is offline
Old 07-26-2012, 05:36 PM   #10
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
Saving for updates
Flat Black VW is offline
Old 07-26-2012, 09:08 PM   #11
ed209
Drives: '12 Mustang GT
lol, more people need to understand this concept.
ed209 is offline
Old 07-26-2012, 09:14 PM   #12
FlipFRS
FlipFRS's Avatar
Drives: Asphalt
260-300 whp, under 5k.. Cant wait to see the finished product
FlipFRS is offline
Old 07-26-2012, 10:11 PM   #13
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
You have my attention...
Parting out HERE
civicdrivr is offline
Old 07-27-2012, 09:24 AM   #14
wcbjr
Drives: 2006 Subaru LGT
Tapping the block? I hope you mean oil pan.
wcbjr is offline
Anyone into DIY ECU tuning? Saibot Engine, Exhaust, Transmission 26 04-25-2012 01:16 PM
BRZ/86 HKS Tuning Parts superhappyfunfun BRZ Photos, Videos, Wallpapers, Gallery Forum 11 04-23-2012 05:44 PM
Using Subarus other turbo Boxers as an idea, how much HP could a turbo BRZ/FR-S have? HitTheGas BRZ First-Gen (2012+) — General Topics 12 02-21-2012 01:24 PM
Tuning Jordo! Engine, Exhaust, Transmission 54 09-05-2010 05:29 PM
Geneva Preview: Techart to debut 911 Turbo, Turbo S vh_supra26 Other Vehicles & General Automotive Discussions 1 02-22-2010 06:20 PM
