My FR-S has 5 gears
Drives: FRS/280z/Tundra
SOLD: 2013 FR-S / 20,004 miles / 2JZGTE / CD00A / Ford 8.8
Reposting as my original post was deleted without me realizing it until today...
There's a lot of modifications to this vehicle, I've put together a list... but I'm sure I'm overlooking a few items. Note, I'm gauging interest prior to dropping a new built billet main/ibeam/cp/625+ shortblock in as I recently hurt the bottom end...(something overkill for the power goals well into the future). Seeing if there's any interest as it sits. Car still runs/drives, but noise is there. Do not need to sale, however I would like to free up garage space for more of a family friendly vehicle. Price: $32,500 USD Mileage: 20,004 Title: Clean ![]() ![]() Engine/Power: 2JZ-GTE Non-vvti GSC S2 (274/274) Camshafts GSC Titanium retainers/valvesprings/Polished Valves ARP 2000 Headstuds/OEM Head Gasket Real Street Performance Billet timing belt tensioner Titan Motorsports Crank Pulley Gates Racing Timing Belt/tensioner Custom serpentine belt tensioner Modified Vavle covers (-10AN Fittings) Powerhouse Racing Billet Coilpack cover Custom Carbon fiber cam gear cover Grimmspeed Hood struts Custom Dual Purpose baffled -10 Catch can/Coolant Overflow tank Modified Coolant Neck -20AN Coolant Hose Griffin Radiator (-20AN) MKIV OEM Waterpump w/185 degree tstat SPAL 16" 3800 CFM Electric Fan Custom Intake Plenum (90MM Throttlebody) 4 BAR Map sensor GM IAT Sensor MS3Pro Ecu Custom Aluminum Charge piping w/Alphaloc quick disconnects x4 Custom Intercooler using 1250HP Treadstone Performance core Turbosmart Raceport BOV Custom Twinscroll T4 sch10 big runner/long runner exhaust manifold ti hardware Dual Turbosmart Hypergate 45mm Wastegates w/hood exit dump tubes (14.5psi springs) Custom wastegate hardlines to electronic boost control solenoid Precision Turbo & Engine 6870 Gen 2 - T4 Divided 1.00ar Turboguard MAXX 4" inlet cover (black/black/carbon) -4AN Oil feed line -10AN Oil drain line Custom 3.5" turboback exhaust (transitions to oval for ground clearance, all tig welded) Vibrant Performance 3.5" inlet, dual 3" exit muffler w/Nameless Performance tips Battery relocated to trunk (Optima Redtop 34/78) Fuel: Radium Engineering Dual Walbro 450 Fuel pump basket x2 Walbro 450 Fuel Pumps (part number 274) Primary pump controlled via ECU Secondary pump staged to come on at 12.5 PSI via Hobbs Switch -8AN Fuel Feed (PTFE) -10AN Center feed fuel rail Injector Dynamics ID1700x Injectors (Stainless internals) Aeromotive Adjustable Fuel Pressure Regulator -6AN Fuel Return line (PTFE) Drivetrain: Nissan CD00A Transmission (latest revision to the 350Z "CD009" transmission) Serialnine "CD999" Shifter w/Serialnine billet knob Collins Adapter JZ to Z Adapter plate Clutch Masters/Collins "Stage 6" twin disc/flywheel (1100ft lb rated) Driveshaft Shop 3.5" Aluminum driveshaft (1000+ HP rating) 2004 Ford Cobra 8.8 Rear differential (3.55 FD & RP gearoil) Ford Performance 8.8 Differential cover Driveshaft Shop 300M Pro level axle kit (1000+ HP rating) Driveshaft Shop Pro level hubs (5x114.3 PCD Option, 1000+ HP Rating) Chassis/Suspension/Wheel/Tire/Brakes: Modified rear subframe (Ford 8.8 solid mount) Whiteline rear upper control arm offset bushings Stance SS+ adjustable coilovers Custom solid engine mounts Custom transmission mount Parts Shop Max 5x114.3 front hubs Gramlight 57DR Wheels Front: 17x9 +38 5x114.3 -- 255/40/17 Toyo R888R Rear: 15x8 +35 5x114.3 -- 275/50/15 Mickey Thompson ET Street R Project Kics R26 lugnuts Stoptech slotted 2005 STI Brembo Rotors (5x114.3) 2007 STI front Brembo calipers EBC Pads Redrilled 5x114.3 OEM Rear rotors Exterior: Orafol Telegrey vinyl wrap (Satin white pearl 37J underneath) 2017 Subaru BRZ Front bumper 2018 BRZ tS bumper inserts Quiklatch mini's x4 Custom Toyota Front Badge (not pictured) 2017+ BRZ APR Carbon fiber front lip The Retrofit source bi-xenon HID projectors in oem headlights Seibon VS Carbon Fiber Hood (cut for wastegates) Aerocatch Hood pins TRD Fender garnishes "winglets" 20% tint OEM BRZ STI sideskirts Chargespeed Rear spats TRD Rear duckbill spoiler TOM`s Tail lights (Japanese market version) JDM Toyota Rear badge Interior: Note: Power steering works along with all oem interior functions excluding traction control & VSC. This includes all HVAC functions. Note the car is wired for air conditioning to work as oem, however the car does not currently have the a/c compressor, condenser, and lines plumbed for A/C. CF Steering wheel trim 2018 GT86 Gauge cluster hood Racepak IQ3S Dashpack Displays rpm, speed, boost, ODO, and water temp currently. Provides turn signal indications via LCD screen. Has warning lights set for AFR/overboost & staged shift light indications. Can be programmed to display many different things if desired. Carbon fiber Racepak holder 2018 GT86 Black Suede Dash trim OEM BeSpoke audio option ![]() ![]() ![]() ![]() ![]() ![]()
Omar GC
2JZ - 6870 - stock block - 1000whp? Instagram: 2jzus Last edited by OmarGC; 06-30-2018 at 06:56 PM. |
My FR-S has 5 gears
Omar GC
2JZ - 6870 - stock block - 1000whp? Instagram: 2jzus |
GOOD GOD that's incredible.
Drives: 13 BRZL/12 Tundra TURD/09 FJR 1300
WOW!
My FR-S has 5 gears
Sold
Omar GC
| FT 2013 Ford Focus ST WTB BRZ/FRS MI | MSUBRZ | Cars for Sale/Trade | 8 | 05-20-2015 08:05 PM |
| FR-S/BRZ vs 2013 Ford Focus ST II | Wes B. | FR-S / BRZ vs.... | 85 | 04-14-2014 04:20 PM |
| 2013 Ford Fiesta ST! | SVTSHC | Other Vehicles & General Automotive Discussions | 26 | 11-28-2012 09:02 AM |
