Old 06-07-2018, 11:18 AM   #1
stlgrym3
Drives: 2017 Subaru BRZ Limited
Jackson Racing C38 vs C30 with stock pulleys
I’m ready to go with JRSC, question now is C30 or C38. I’m fully aware what the differences are between the two. For $100 more I’d be dumb not to pick the C38 with higher power potentials down the road. However, I do plan on keeping stock pulleys and running on 91 gas for the foreseeable future.
My main concern with getting C38 now is Jackson Racing does not have CARB tune for 2017+ model yet, therefore I’d have to stick with my Tomei EL header and go with Delicious Tuning Flash and Go tune. Has anyone here with C38 , stock pulleys and a non-factory tune? How do you like it?
Also I’ve heard C30 does provide more power down low whereas C38 has more room for power in upper RPMs, is the difference quite big and obvious down low?
stlgrym3 is offline   Reply With Quote
Old 06-07-2018, 01:00 PM   #2
Unless you plan on a built motor and the RS pulley upgrade, the potential of the larger supercharger is largely meaningless.
It's like getting a giant turbocharger "for the potential", knowing you realistically would probably never use it.
Do you see yourself building an engine in the next 2 years or so?
The Following 4 Users Say Thank You to CSG Mike For This Useful Post:
jkamelo (10-08-2021), mrg666 (02-17-2019), Sapphireho (06-07-2018), Tristor (06-08-2018)
Old 06-07-2018, 01:11 PM   #3
stlgrym3
No I do not planning on rebuild motor. However, I do planning on getting ACE header, HBP and flex fuel kit down the road. Can stock motor handle C38’s potential with those supporting mods?
Old 06-07-2018, 01:18 PM   #4
Can it? Yes. How long? Luck of the draw.
Again, unless you're getting the RS pulley, you are not exploiting the potential of the C38.
Old 06-07-2018, 01:19 PM   #5
stlgrym3
What’s RS pulley?
Old 06-07-2018, 01:38 PM   #6
Originally Posted by stlgrym3 View Post
What’s RS pulley?
The "super high boost" pulley a C30 cannot use.
Old 06-07-2018, 01:50 PM   #7
stlgrym3
Now what are the cons of getting C38 over C30 if I do not planning on exploring the full potentials of C38? Other than the $100 premium of course.
Old 06-07-2018, 03:34 PM   #8
twag4
Drives: frs
I’m gonna rock the boat and say no. I was on c30 with standard pulley, ace type a350, and flexfuel, and a rod broke at probably 2500rpm. It was massive catastrophic damage. Only one head blank could be salvaged. I didn’t routinely redline the engine. The rods and apparently rod bearings are the weak links in this engine. My rod bearings were not damaged at all.
twag4 is offline   Reply With Quote
The Following 4 Users Say Thank You to twag4 For This Useful Post:
CSG Mike (06-07-2018), jcw99 (08-18-2019), Tristor (06-08-2018), weepel (05-26-2020)
Old 06-08-2018, 12:39 AM   #9
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
What's the whp potential of a C30? I'm currently building a motor with stronger rods for insurance if I decide to go boosted later down the road (maybe next year). I'd only be looking for up to 300whp. C30 handle that with ease?
JimmyMac is offline   Reply With Quote
Old 06-08-2018, 12:45 AM   #10
twag4
Drives: frs
If you can do flex fuel, you’ll exceed that. It’ll be less by some margin if you do 93 octane and a good header. I was a spec over 280 with that setup on 93 octane and ace header
The Following 2 Users Say Thank You to twag4 For This Useful Post:
jcw99 (08-18-2019), JimmyMac (06-08-2018)
Old 06-08-2018, 12:55 AM   #11
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
What or who was the tuner?
Old 06-08-2018, 12:57 AM   #12
Irace86.2.0
Maybe weight. Maybe less efficiency.
Old 06-08-2018, 07:34 AM   #13
twag4
Drives: frs
Delicious on ecutek
The Following User Says Thank You to twag4 For This Useful Post:
Irace86.2.0 (06-08-2018)
Old 06-08-2018, 02:34 PM   #14
majixmatrix
BRZ Wannabee
majixmatrix's Avatar
Drives: 2013 Limited BRZ
Delicious on ecutek
Dang, seems to be pretty hit or miss for some people. I have a friend who has the high boost pulley on a C38 and flexfuel who's been dailying it for months with no problems!! I can't trust off the shelf tunes haha but Delicious makes good stuff.
majixmatrix is offline   Reply With Quote
CounterSpace Garage Forced Induction || Jackson Racing | Edelbrock (IN STOCK!!)|| CounterSpace Garage Forced Induction 66 08-09-2016 01:59 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Ti Racing pulleys diss7 Engine, Exhaust, Transmission 0 12-17-2013 03:15 PM
Jackson Racing FR-S Unleashed FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 11-18-2012 02:29 PM
