Old 06-06-2018, 09:28 PM   #1
Turbo
Drives: FR-S Turbo
Turbo exhaust suggestions, please
To the guys running turbos - what are you running for exhaust?
Is there anything out there that will give the car that super deep exhaust throb that the guys in WRX STi's seem to have?
The system the previous owner put on my car sounds a bit tin-ny - that is, when it isn't droning like crazy. It's driving me nuts, so I've gotta change it up.
Is there a sound-clip database for turbo cars that I just can't find with the search?
Turbo is offline   Reply With Quote
Old 06-07-2018, 09:30 AM   #2
Timmy_Jones
Spun
Drives: 17' Focus RS
I am inclined to think it has to do with exhaust diameter. I seem to notice that going from a 3" exhaust to a 2.5" exhaust really changes volume and low end bass. The 3" was louder and absolutely had more bass. Any idea whats on there now? grab a caliper and check, if its 2.5" or less, the 3" really should change the sound (I would address the muffler/resonators as well).
Timmy_Jones is offline   Reply With Quote
Old 06-07-2018, 11:20 AM   #3
Sarang
Drives: 2010 LGT
That throb is fron the STIs unequal length headers. If you do not have that, no throb for you.
Sarang is offline   Reply With Quote
Old 06-09-2018, 06:10 PM   #4
thecarfilmer
IG: @nickwiththefrs
thecarfilmer's Avatar
Drives: 2016 Scion FR-S Halo
im running the JDL UEL V2 turbo kit and with my exhaust setup, it almost sounds similar.
so it goes the uel manifold, tomei overpipe, invidia catless front pipe and greddy rs race 3in catback
thecarfilmer is offline   Reply With Quote
Old 06-09-2018, 10:39 PM   #5
I do 360whp on a stock front pipe and stock catback.
Are you sure you need an exhaust?
Old 06-10-2018, 12:12 AM   #6
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
I think the best performing one would be Tomei Type 80
If you're looking for that deep exhaust I think you're looking for the Perrin one with UELs
Alltezza is offline   Reply With Quote
Old 06-10-2018, 05:00 PM   #7
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
If you don't like droning, don't go for the Tomei Type 80 or basically any single exit exhaust. They can be LAF!! hehe
JimmyMac is offline   Reply With Quote
Old 06-10-2018, 05:39 PM   #8
tyler_win_photo
tyler_win_photo's Avatar
Perrin 3" would give you a nice deep sound.
tyler_win_photo is offline   Reply With Quote
Old 06-10-2018, 05:40 PM   #9
NRXRaptor
did op died?
NRXRaptor is offline   Reply With Quote
Old 06-11-2018, 01:17 AM   #10
Turbo
Drives: FR-S Turbo
Originally Posted by NRXRaptor View Post
did op died?
From ear-drum damage, yes
My car is certainly a lot tamer then yours, Mike.
However, the aftermarket exhaust currently on the car drones like hell and is a bit too loud - so I've got to do something. Beyond the drone (which happens between 2,000-3,000rpm under load or not) it actually doesn't sound that bad at all. A bit loud, perhaps but installing the 'silencers' helps with that.
The exhaust on the car right now is the "Spec-D Tuning" catback. It appears to be a no-name copy of the Invidia N1.
I've tossed around the idea of making a new mid-pipe with a high-quality resonator to see if that solves the problem, but would love to hear other thoughts.
Anyone else have experience with this particular exhaust ?
Old 06-11-2018, 01:56 AM   #11
tyler_win_photo
If you haven't already you can try a dual resonator in the front pipe. It would help with the drone.
The Following User Says Thank You to tyler_win_photo For This Useful Post:
Turbo (06-11-2018)
Old 06-11-2018, 03:03 AM   #12
JimmyMac
JimmyMac's Avatar
I've run the Invidia N1 in the past (before I had a turbo) and it was drone city. I've tried all sorts of front pipes to get rid of it, but none have helped. For the most part, they just shifted the drone up the rpm range. Never got rid of it. I just got used to shifting sooner at lower speeds to stay out of the drone zone, but at highway speeds there was no avoiding it. Went back to the stock catback and it was sooo peaceful! haha
Then I went turbo I jumped on an 80R just because. Ears were bleeding (I guess I'm just old haha). Back to stock catback and NA, but thinking of trying a supercharger next year after I finish building my motor. More than likely I'll stick with the stock catback and frontpipe or try a Blitz catback.
Now don't get me wrong, I did love the N1. Especially at idle. Sounded nice and got a lot of compliments on it. But on road trips it just got old fast. You can try a larger/better resonator as you suggested, but I think part of the drone comes from the straight through canister style muffler. Silencers did help with sound and drone in past cars, but I could never get them to fit correctly on the N1. Plus I felt like I lost some bottom end when I had them installed.
Old 06-11-2018, 03:30 AM   #13
BrQ
Drives: 13 BRZ
That's not even what he asked.
BrQ is offline   Reply With Quote
The Following User Says Thank You to BrQ For This Useful Post:
tyler_win_photo (06-11-2018)
Old 06-27-2018, 08:42 PM   #14
Jmorph
Drives: 2013 FRS w/SBD500X
Same situation here, current exhaust way too loud/drone with turbo. I was looking at q300 to quiet it down, thoughts?
Jmorph is offline   Reply With Quote
Need clutch suggestions for daily driving a Turbo FRS CamFrs Engine, Exhaust, Transmission 8 04-04-2017 07:27 PM
Need exhaust suggestions. wise345 Engine, Exhaust, Transmission 19 02-23-2016 08:10 PM
Exhaust Suggestions bunches7399 Engine, Exhaust, Transmission 4 09-24-2014 10:59 PM
Looking for exhaust tip suggestions paiceyfan Engine, Exhaust, Transmission 15 06-23-2014 11:31 PM
Need some suggestions on my exhaust aymen23q Engine, Exhaust, Transmission 1 01-25-2013 05:37 AM
