Drives: 2017 86 Asphalt
Buying Tomei UEL used
Hi, I plan on buying a used tomei UEL header soon. It will come with no gaskets or hardware. My current stock car has only 5000 miles and is only 4 months old so there shouldn't be any rust or too much wear on stock parts. What all should I buy to install the UEL headers? I assume O2 spacer and the grimmspeed gasket(1 or 2?) are two of the things I should buy? Just want to make sure I do things right, thanks in advance!
You should buy the gaskets but skip the O2 sensor spacer if your intention is to do it right. You should get a tune that is calibrated for changing the header. OFT or a Tactrix cable will be the least expensive path as you can flash off the shelf maps with no additional cost on top of the hardware.
you may need nuts and bolts to connect it to the over pipe
| TOMEI now in stock @OAKOS! We are an offical TOMEI stocking Vendor! | OAKOS Automotive | Engine, Exhaust, Bolt-Ons | 313 | 03-11-2020 10:35 AM |
| Buying tomei 60r. | carlovestela | Want-To-Buy Requests | 0 | 03-28-2018 11:49 PM |
| FRS – Tomei UEL, Tomei Overpipe, Stock Front Pipe, Manzo V2 exhaust | Timmy_Jones | Engine, Exhaust, Transmission | 0 | 05-01-2017 10:29 AM |
| [Sold] TOMEI Tomei Powered Expreme TI Type-80 Catback | Richytort | Engine, Exhaust, Bolt-Ons | 5 | 08-26-2016 02:59 AM |
