Old 05-28-2018, 03:02 PM   #1
stlgrym3
Drives: 2017 Subaru BRZ Limited
Is my mpg normal?
Mine has OFT stage 2+ tune with tomei EL header, right now I’m getting 23.5mpg mix driving with 60% street and 40% highway. It was about the same when the car was unmodded. Does this number look low or normal?
stlgrym3 is offline   Reply With Quote
Old 05-28-2018, 03:26 PM   #2
carsebuco
How do I shift?
carsebuco's Avatar
Drives: '13 GBS BRZ
Based on personal experience, it sounds about right. I ran 31mpg on stage 1, about 22 on stage 2.
carsebuco is offline   Reply With Quote
Old 05-28-2018, 04:37 PM   #3
Impureclient
Drives: 2015 FR-S
You must be driving it too easy, grandpa. OFT with custom tune and UEL here and I get 20 mpg.
Mine is almost exclusively city driving though. If I take it easy, which I rarely do, it will be closer to 25 mpg. Highway and taking is 35+ mpg though.
Impureclient is offline   Reply With Quote
Old 05-28-2018, 04:39 PM   #4
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
How are you measuring this MPG?
The Following User Says Thank You to mav1178 For This Useful Post:
Spuds (05-29-2018)
Old 05-28-2018, 04:42 PM   #5
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
my last tank i didnt even get 20mpg with my ace headers, but it was all city driving and short trips
Breadman is offline   Reply With Quote
Old 05-28-2018, 05:00 PM   #6
There is no "normal". Everybody will have something different depending on how and where they drive.
Old 05-28-2018, 07:23 PM   #7
murdoc
Sometimes I'm wrong.
murdoc's Avatar
Drives: '13 FR-S/'96 240SX
I get 21mpg on e85, I must drive like granny.
murdoc is offline   Reply With Quote
Old 05-29-2018, 09:21 PM   #8
Whoodoo
Drives: '15 BRZ, Vortech supercharger
I must be doing it wrong... I've never seen less than 29mpg on the dash
Whoodoo is offline   Reply With Quote
The Following User Says Thank You to Whoodoo For This Useful Post:
Somerandom18 (05-29-2018)
Old 05-29-2018, 10:32 PM   #9
Somerandom18
Drives: 2017 manual BRZ
Mine always plummets with a fresh reflash then goes back to 29.4 on the dot every time.
Sent from my Pixel XL using Tapatalk
Somerandom18 is offline   Reply With Quote
Old 05-29-2018, 11:37 PM   #10
NRXRaptor
I'm running OFT stage 2 tune UEL headers and when my tank went from full to 1/8th remaining I had covered 300 miles. Probably could have gone at least 30 more miles. I drive a mix of city and highway, but its all short trips
NRXRaptor is offline   Reply With Quote
Old 05-30-2018, 12:00 PM   #11
DeltaEcho
DeltaEcho's Avatar
Drives: 17BRZ Limited TS
So far running OFT Stage 2+
Let me preface that I drive conservatively. Here are the averages I have been receiving.
City: 22-26 mpg
Highway: 26-30 mpg
Highway Cruise Control: 30-34 mpg
Error of Margin [+ or -] 2 mpg
DeltaEcho is offline   Reply With Quote
Old 05-30-2018, 03:49 PM   #12
Soloside
-Phil's BIGGEST FAN BOI
Drives: 2014 Greddy Turbo BRZ
Turbo and rarely ever get into boost and only average sub 20 (18s-19s) on pump gas.
Sad life.
2014 Subaru BRZ
Don't follow your dreams, follow my instagram www.instagram.com/soloside
Soloside is offline   Reply With Quote
Old 05-30-2018, 06:45 PM   #13
bfrank1972
Drives: 2013 FR-S Argento
Depends on a lot of factors:
- heavy foot
- nervous foot (lots of on off), no cruise
- lots of short trips, motor not warmed up, even if short highway, this makes a big difference
- proportion of highway to city
- terrain, hilly or flat
- tire pressures and tires to a minor degree
- oil viscosity to a minor degree
Sent from my SM-N920V using Tapatalk
bfrank1972 is offline   Reply With Quote
Is this engine noise normal? (Consensus - normal) StraightOuttaCanadaEh Issues | Warranty | Recalls / TSB 31 02-05-2018 04:01 PM
IS IT NORMAL WGMGR Scion FR-S / Toyota 86 GT86 General Forum 40 12-08-2014 06:19 PM
Is this normal? Prostreet513 Electronics | Audio | NAV | Infotainment 1 09-19-2014 09:08 AM
Does this look normal to you? white_knight Issues | Warranty | Recalls / TSB 13 03-03-2013 04:10 AM
Is it normal to see a .... Mango22 BRZ First-Gen (2012+) — General Topics 10 10-12-2012 03:54 PM
