Old 05-23-2018, 06:56 PM   #1
_______
_______'s Avatar
Drives: SWP Subaru BRZ
OFT cable busted
Does anyone know where I could acquire a new V1 OFT cable? Any little movement of the cable will cause the screen to scramble and will shut off my OFT. I won't be able to load new tunes or data log because the cable seems very sensitive to any movement.
I know I should ask Shiv but since they are real busy these days I will not get an immediate answer. I'd thought I would see if anyone could help me out here.
_______ is offline   Reply With Quote
Old 05-23-2018, 07:54 PM   #2
steve99
try
https://www.alientech-usa.com/
oft is an alientech powergate 3
however it might be the obd port in your car that is the problem
Old 05-23-2018, 08:10 PM   #3
Decep
Drives: 2013 FR-S Series 10
just the odb2 cable? i got one off amazon.
Old 05-23-2018, 10:34 PM   #4
steve99
You mean usb cable ??, The oft to obd cable isnt a standard cable easily found ?
Old 05-23-2018, 11:40 PM   #5
Xnthny
Drives: WRB
alien tech sells them for $25. Contact anywhere that sells the OFT. Ive had quotes from 15-25 shipped. Your best bet would be to contact shiv he would probably have the best deal.
Xnthny is offline   Reply With Quote
The Following User Says Thank You to Xnthny For This Useful Post:
Teseo (05-24-2018)
Old 05-23-2018, 11:54 PM   #6
_______
_______'s Avatar
try
Thanks for the info, Open Flash team got back to me after I sent them an email, they are going to give me a replacement. Now that you mention it could be my OBD port, how could I check to see if that is the problem?
Old 05-23-2018, 11:56 PM   #7
_______
_______'s Avatar
Luckily I was able to get a hold of them, they will be giving me a replacement.
Old 05-24-2018, 03:09 AM   #8
steve99
if the new cable doesnt sort it its likey the obd port connector in car
Old 05-24-2018, 02:36 PM   #9
Baron_T
Drives: 2014 BRZ
For improving the connection, I had good luck taking a fine pair of needle-nose pliers, grabbing each pin about half-way down, and gently twisting each pin a little bit. You need to keep the pins straight up-and-down, and I only need about an eighth turn twist in each, but this effectively makes the pins a bit thicker and gives each pin a bit of pin edge to contact the pair-of-leaves socket in the car's connector.
Gently
Baron_T is offline   Reply With Quote
Old 05-24-2018, 06:43 PM   #10
Decep
sorry brain fart. it was an extension cable i bought.
Is this a busted sway arm bushing? ironsurfer129 Issues | Warranty | Recalls / TSB 9 08-26-2017 01:09 AM
BUSTED.....was it someone on the Forums? White64Goat Southeast 1 03-24-2016 12:59 PM
busted codes? finch1750 Site Announcements / Questions / Issues 9 02-01-2016 12:12 PM
Busted Sun Visor mount cycleboy Issues | Warranty | Recalls / TSB 3 07-10-2015 08:26 PM
FS: ARK DTS 2 busted flanges Sgt.Beardface Engine, Exhaust, Bolt-Ons 5 05-11-2014 12:34 PM
