Old 05-20-2018, 03:59 PM   #1
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
Stock 86 and E98....
My local E85 dealer is considering carrying E98 instead. Currently running E85 and the V4 OFT E85 tune on my stock 17 86.
As far as I know and can determine, E98 SHOULD be OK on the OTS tune.
Correct?
Thanks, smarterer dudes!
PetrolioBenzina is offline   Reply With Quote
Old 05-21-2018, 05:04 AM   #2
steve99
Its going to run high fuel trims unless you tweak fueling.
E98 is not going to start in cold temps
You might just want to mix in 10-15% petrol into it
PetrolioBenzina (05-21-2018)
Old 05-21-2018, 06:18 PM   #3
PetrolioBenzina
Drives: 17 86
Thanks. We do get cold enough here for trouble starting with E85, and DIY blending sounds like PITA without my own garage space.
Might be fun to mix up a five gallon can, though.
Old 05-22-2018, 05:14 AM   #4
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
It's not a perfect science, the tune can handle from 60-90% ethanol. You don't have to blend in a can, just stop at the pump, put in (from E) 2 gals of 93 then fill up on the E98. It'll be close enough to be perfect.
The Following User Says Thank You to guybo For This Useful Post:
PetrolioBenzina (05-22-2018)
Old 05-22-2018, 11:01 AM   #5
PetrolioBenzina
Drives: 17 86
Sounds easy. Highest we have here is 92, though. Still might try the can, as that would give me just five gallons to check with, rather than a full tank. At 18 mpg of E85, I could empty that in no time at all.
Need to stop buy and see if this is moving forward.
Thanks!
Old 05-22-2018, 01:59 PM   #6
guybo
Huge E85 fan!
guybo's Avatar
I get about 19 mpg and with a 13.5 gal tank and a 45 Mike round trip commute.... My tank feels awfully small! The OFT tune is good from E60 to E90, there's no performance benefit from anything more than 60% ethanol. There's a lot of info on this forum about it. My car feels so much better on corn juice too. You can use a wide range of ethanol % because E85 is much more tolerant of a wider ranger of AFR, unlike gas that only makes power in a very narrow AFR range.
FS: Stock brake lines, stock clutch line, stock motor mounts Agent_D Brakes, Suspension, Chassis 4 08-22-2017 12:24 PM
FS: Openflash, Weathertechs,Mtech Trasmission Springs, Stock Exhaust, Stock intake Brahsbrah Canada Classifieds 11 11-09-2014 11:03 AM
WTB: Stock MAP Sensor, Stock Frontpipe, Stock Midpipe. Sterz Engine, Exhaust, Bolt-Ons 4 07-02-2014 09:22 PM
WTS: Airaid Intake System, Stock Exhaust, Stock Radiator Hoses Sony Engine, Exhaust, Bolt-Ons 0 11-20-2012 11:10 PM
