Old 05-17-2018, 07:15 PM   #1
sfruski
Drives: Many
Looking for comparison data for Thunderhill and Sonoma Racway
I'm looking for top speeds at both Thunderhill and Sonoma?
I've been chasing an issue and can't seem to find it. I'm trying to determine if something is funny with the engine, possibly belt slip.
I'm hitting 109mph at Sonoma and 112mph at Thunderhill. Sonoma is a little low, but Thunderhilll was expecting around 120mph.
If you can, tell me your weight, power, and wing/splitter (if any):
2750 race weight with driver
JRSC - 91 oct - 235whp, 180wtq
Aeromotions Wing
Thanks
sfruski is offline   Reply With Quote
Old 05-17-2018, 09:38 PM   #2
juliog
juliog's Avatar
Drives: 86
What tire model and size are you on? Have GPS logs?
juliog is offline   Reply With Quote
Old 05-17-2018, 11:41 PM   #3
Aeromotions Wing
Thanks
Post your datalog
Old 05-18-2018, 04:17 AM   #4
sfruski
Drives: Many
Tires are 255/40/17 NT01s, so the spedo is only slightly off. I'm putting in an external data loger/gps video monitor for this weekends event: 5/19/18. (Racekeeper)
I've attached the ecutec datalog from a Sonoma event and Thunderhill event, if that is what you are interested in. Only engine thing changed on the car between the two events was the addition of a Fluidamper crank pulley for the Thunderhill event.
Old 05-18-2018, 02:05 PM   #5
I recommend you get a track datalogger, like an AIM Solo 2 DL.
PM me to order.
The Ecutek log is not enough for me to truly compare with other data I have. I need either Motec, Racepak, Bosch, or AIM type logs.
Old 05-22-2018, 01:41 PM   #6
sfruski
Drives: Many
PM me to order.
Here is the export from my Racekeeper datalooger. Not sure if it is compatible with the aim type of logs.
Old 05-22-2018, 03:36 PM   #7
I need a datalog with more telemetry, or an ecutek log.
I cannot help you with the log you provided, as it doesn't have enough parameters for me to look at that can potentially give me a clue on what is wrong with your car, if anything is wrong.
As a reference, in a s2000 with a stock motor, I typically see 115mph or so down the front straight at thunderhill.
At this point, I still have zero clue if its driver or car or both. I cannot help you if you cannot provide me with useful information.
HooptieCon at Sonoma 3/24/18: Lemons + Radwood! TofuJoe Northern California 10 04-22-2018 01:36 AM
IRL Sonoma race? Dave-ROR Northern California 17 08-22-2014 11:05 AM
My 1st HPDE @ Sonoma Raceway! tintumz22 Tracking / Autocross / HPDE / Drifting 14 04-02-2013 01:42 PM
Swap Meet @ Sonoma Raceway 2/2/13 86_ZN6 Northern California 1 01-30-2013 03:54 AM
Before/After Track Times (Sonoma Raceway) CorteXracing Tracking / Autocross / HPDE / Drifting 5 11-26-2012 10:28 PM
