Old 05-15-2018, 07:14 PM   #1
5150
5150's Avatar
Drives: 2017 86
2017 86 rear bumper diffuser trim dent
I got a small dent on my black trim diffuser. Is it possible to bondo it and paint it? I don't want to get a new bumper or add on diffuser.
5150 is offline   Reply With Quote
Old 05-16-2018, 08:20 AM   #2
abevil
abevil's Avatar
Drives: 2017 BRZ Pure Red w/PP
I would also love to know if this is possible. My 2017 BRZ rear bumper got tapped and I have a nice outline of someone’s license plate hardware in the plastic part of my diffuser. Bothers me everyday...
abevil is offline   Reply With Quote
Old 05-16-2018, 08:21 AM   #3
Tokay444
Anti stance.
Tokay444's Avatar
Try a heat gun and massaging it out from behind.
Old 05-16-2018, 08:33 AM   #4
15limited
15limited's Avatar
Cant seem to view your pictures. But based off your description you will be able to fill the dents and paint but matching the weaved texture would be next to impossible. imo it would probably look worse with anytlkind of repair, or by time you pay someone to spend enough to time fix it, you're already at the cost of a new one.
Sent from my SM-G950U using Tapatalk
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
Old 05-16-2018, 08:54 AM   #5
Tokay444
Anti stance.
Tokay444's Avatar
No weave texture on a '17.
Old 05-16-2018, 09:44 AM   #6
Bondo is rigid the plastic is flexible so it rarely works well. There are proper fillers for plastic though.
This ^ should be the first attempt.
No weave but still textured. Wouldn't be impossible to match the pebble texture but could be very difficult.
Old 05-16-2018, 10:00 AM   #7
churchx
churchx's Avatar
Drives: 2014 GT86
hard to match .. so just plastidip or cover with vinyl whole part?
Old 05-16-2018, 07:24 PM   #8
5150
5150's Avatar
Drives: 2017 86
I might just sand the whole trim and paint the whole diffuser. Do you guys think that will work?
Old 05-16-2018, 09:12 PM   #9
Try the heat first
RB rear diffuser v3 on 2017 86? 5150 Cosmetic Modification (Interior/Exterior/Lighting) 0 03-04-2018 04:47 PM
JDM Rear Diffuser compatible with NA bumper? Ethereal05 Cosmetic Modification (Interior/Exterior/Lighting) 10 12-02-2017 02:14 PM
2017 86 - Rear Diffuser lonewolfworks Cosmetic Modification (Interior/Exterior/Lighting) 41 11-07-2017 01:11 PM
Removing the rear oem bumper diffuser kjjimnz Cosmetic Modification (Interior/Exterior/Lighting) 12 03-13-2015 06:35 PM
Big Dent in rear bumper, any carbon fiber rear ends? bdohazelnuts Cosmetic Modification (Interior/Exterior/Lighting) 4 10-22-2013 04:22 PM
