Old 05-12-2018, 05:11 PM   #1
trippinbillies40
trippinbillies40's Avatar
Drives: '22 WRB
RCE Tarmac 2 adjustment recommendations
Howdy friends. I purchased an STX autocross car a few weeks ago that has RCE T2s on it. It's got a 20mm whiteline front bar, and I'm not sure what the rear bar is, but it's black and has 3 holes of adjustment and is set on soft. Need to dig into it further to figure out what it is.
Anyways, I'm getting the car aligned and corner balanced later this week. Any recommendations on where to set the dampers for autocross? I like a car that turns in sharp and rotates decently on corner entry, and is neutral to ever so slightly loose on throttle.
We autocrossed it the morning after getting home at midnight after picking it up, and it pushed like a dump truck on throttle. Finally checked the damper settings today, they were at FR: 5, FB: 2, RR: 7, RB: 0. That probably explains the push haha.
Any recommendations for a starting point on bump and rebound settings would be much appreciated.
trippinbillies40 is offline   Reply With Quote
Old 05-12-2018, 07:57 PM   #2
Dynamhik
I've had good luck with
Rebound (from full stiff) - 10(F), 13(R)
Comp (from full stiff) - 11(F), 8(R)
Depending on surface I may add a little more compression rear, but this did me well at Crows Landing (concrete) as well asphalt. This is all with the same front bar and stock rear.
The rear bar is probably Mann Engineering.
Dynamhik is offline   Reply With Quote
The Following User Says Thank You to Dynamhik For This Useful Post:
Racecomp Engineering (05-21-2018)
Old 05-12-2018, 09:01 PM   #3
trippinbillies40
Drives: '22 WRB
Thank you!! And yes, it's a Mann. It was on full soft, so I changed it to full stiff to be equivalent to OE. Hopefully it actually turns tomorrow haha.
Old 05-12-2018, 09:16 PM   #4
Briankbot
Briankbot's Avatar
Drives: 2013 FRS
This might be helpful when it comes to damper adjustments.
http://www.smithees-racetech.com.au/...hocktune1.html
Briankbot is offline   Reply With Quote
Old 05-12-2018, 10:39 PM   #5
cjd
cjd's Avatar
Drives: 2017 BRZ
Stock springs? Any idea what the alignment is? Hopefully in the ballpark.
I don't run T2's but RCE has been amazing to work with even though I purchased a second hand set of their coilovers. They have published their recommended starting settings: http://racecompengineering.com/instr...ingsbrzfrs.pdf
The Following User Says Thank You to cjd For This Useful Post:
Old 05-21-2018, 02:31 PM   #6
Completely missed this...I was kinda sick last week and not on the forums too much.
Feel free to PM me if you need any extra tips for your specific set up.
- Andrew
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
trippinbillies40 (06-02-2018)
RCE Tarmac 2 - top nut adjustment milhouse Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 07-24-2025 05:53 AM
RCE Tarmac 2 CLUBSPORT and RCE Tarmac 0 coilovers available now Racecomp Engineering Suspension | Chassis | Brakes -- Sponsored by 949 Racing 589 11-21-2021 04:13 PM
New ECU vin adjustment sfruski Northern California 3 11-24-2017 08:59 PM
***FT-86 SpeedFactory RCE Tarmac 2 Clubsport and Tarmac Zero Sale Thread*** FT-86 SpeedFactory Brakes, Suspension, Chassis 208 09-30-2016 03:43 PM
Camber adjustment ThatManAnt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 09-04-2014 07:47 AM
