Old 05-08-2018, 07:23 PM   #1
Student Driver
Drives: 2013 Scion FRS Series 10
P2M Rear Upper Control Arms
Has anyone had any experience with P2M Rear Upper Control Arms? I have looked everywhere I could think of and not been able to find anything on them. I have only seen them mentioned on the forums once and it had no information on them and couldn't find any reviews via google. If anyone has any experience with these I would love to know what you think. I am specifically curious of how adjustable they are, I have sent an email out to the company that makes them but haven't heard back yet. If this ends up hitting a dead end i will probably pull the trigger on some Racer X RUCA but if possible would like to avoid paying that much if there are other options out there. TIA!
Student Driver is offline   Reply With Quote
Old 05-15-2018, 12:07 PM   #2
Student Driver
Has literally no one tried these out?!
Old 05-15-2018, 12:37 PM   #3
churchx
churchx's Avatar
Drives: 2014 GT86
For what purpose upper? Shouldn't lower control arms be cheaper?
Old 05-15-2018, 01:07 PM   #4
Student Driver
They are a little cheaper yes, but I have every adjustable arm for the rear of my car except the upper control arm... I need a bit more negative camber from the top end to clear my wheels and just need to know how much adjustment these actually provide.
I know racer x is probably my best option since they show the range of camber you get so I know what I am getting into but the 2 - 3 month turn around time for there products really leaves a bad taste in my mouth...
I have recently stumbled upon Dominant Engineering as well and am looking into there turn around times, though they are quite a bit more expensive.
Old 05-15-2018, 01:09 PM   #5
Code Monkey
Drives: Subaru BRZ
If you think RacerX are expensive, try MSI.
I have been running RacerX RUCA's for almost 8,000 miles now with 8 hpde weekends or so, zero problems so far.
Code Monkey is offline   Reply With Quote
Old 05-15-2018, 01:19 PM   #6
Student Driver
I meant the Dominant Engineering ones were expensive, but those are even more! how long did it take for you to get your RUCA from Racer X?
Old 05-15-2018, 03:03 PM   #7
Code Monkey
Drives: Subaru BRZ
I emailed them before I ordered to make sure they were in stock so there was no wait time once Racer X confirmed they had them.
Old 05-15-2018, 04:53 PM   #8
Student Driver
I should definitely do the same then! Thanks for that info! Out of the 4 people I have talked to you are the first to say it has not taken 2-3 months so I will give them a call or email them to see if they have what I need.
Old 05-17-2018, 10:04 PM   #9
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
P2M tested the arms on my car. In fact, all the rear arms were on my car.
http://www.phase2motortrend.com/prod...uca2086-hc.htm
Pics of the arms on the car were of my car when I had Ohlins.
I didn't keep it long enough to learn anything useful about them
-alex
Old 05-19-2018, 01:35 AM   #10
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
If you're looking for rear uppers to get even more camber you should look elsewhere. I know and have dealt with the nice folks that manufactures these. Very good quality and track tested, but will not do what you're looking to do.
Intent > Content
Old 05-21-2018, 12:25 PM   #11
Brzxton
Drives: 2015 Subaru Brz
It depends on what they are made for. Racerx makes ruca that give -4~-9 andone tgat goes -9~-14 i believe.
Brzxton is offline   Reply With Quote
Old 05-21-2018, 01:39 PM   #12
Student Driver
Glad to hear this! I actually just bought the -9 to -14 racer x arms last week, so i am glad i didnt end up pulling the trigger on P2M
Old 05-21-2018, 04:39 PM   #13
solidONE
solidONE's Avatar
At the minimum adjustment these arms are slightly longer than factory dimensions, unless they've revised it. This is why they will not give him any more negative adjustment he desires. For people not looking to "stance" they still must be paired with their lower control arms.
Intent > Content
OEM rear upper control arms -- SOLD Code Monkey Brakes, Suspension, Chassis 13 07-28-2018 07:28 PM
RacerX Rear Upper Control Arms 636 Brakes, Suspension, Chassis 2 01-05-2017 10:05 PM
FS: Rear Upper Control Arms MicheleAbbate Brakes, Suspension, Chassis 1 05-03-2016 06:44 PM
Adjustable rear upper control arms??? Supermassive Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 09-29-2013 09:17 AM
Oem rear upper control arms Jhon19lopez Brakes, Suspension, Chassis 1 08-25-2013 09:01 PM
